Results 1 to 10 of 11
Thread: Unknown fault code: P0602 HELP PLS!
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Default Unknown fault code: P0602 HELP PLS!
    Had a tech 2 on the signum today as the spanner and car light came on my dash.
    Outcome is P0602 = variant configeration unknown.
    VX mechanic didnt have this number in the VX T.I.S?
    Any ideas anyone?
    Woodsta
    Regular Member benny's Avatar
    Feb 2006
    dudley
    ..was the tech two upto date useing the latest vx softwear ?.......variant configuration is where a ecu has been fitted and not programed correctly or the ecu has gone faulty on the programing side ..did he tell you witch ecu he pulled the code from ?.....
    variant config is the set up of the car ...it does differ from ecu to ecu ..but it is common sense stuff really ..like how many doors does the car have what model is the car what enigne is fitted and what side the driver sits ....have you had any ecu's fitted recently ..or have you retro fitted anything ...if you havent you may have a fault with the ecu the code was pulled from ...hope this helps benny
    May 2006
    Kent
    No sorry i dont know what version the tech 2 was? my signum is a 54 reg
    The mechanic said with a bit of time he could try to sort it out but i think they just wanted to fob me off for another day.
    I havnt had a new ecu or retro done?
    Im going back on wednesday.
    Oh when i took it in this code wasnt present only a boost code fault. this fault came up after the boost was sorted (a hose had split)
    Could he have deleted or cleared some data?
    Is it as easy as updating the data with a new version or something more drastic and expensive?
    Woodsta
    Feb 2006
    dudley
    ah ok that explains it ..beeing as it is a early car the canbus systems can be lets say ..um **** ...if you start the car with ya foot on the brake with tec two pluged in it will throw up allsorts a codes ......best just forget about it aslong as the light is not still on ,..ive had cars where ive done nowt to the system and start it up with me foot on the brake and all hell is let loose flashing lights none starts and so on ....tech two loves to confuse the situation ......
    May 2006
    Kent
    Oh Great! Can it be updated?
    Feb 2006
    dudley
    can what be updated ? .....if you mean tech two yes but it is down to the dealer to do that ....
    May 2006
    Kent
    Ok cool, i will ask them to upgrade the Tech 2 on wednesday. hopefully that will sort it out.
    Thanks for you help, nice one.
    Woodsta
    Feb 2006
    dudley
    you got your own tech two? if you have had it tested at a vx dealer they will allready be updated to the latest data.......
    Belfast
    I think someone is confused about what a Tech2 is...
    That code seems to throw up two possible errors:
    Control Module Programming Error or
    Vehicle Identification Number missing
    Both suggest there's something goosed in the ECU that it's not storing it's configuration.
    May 2006
    Kent
    Default I think VX have sorted it?
    OK ive got my Signum back and VX said that my ECU was set up for the 120 engine? mine is the 150 CDTi.
    They asked if i had chipped or remapped the ECU? which i hadnt.
    But ive never played with the ECU and ive always taken my Signum to the same VX dealers since i bought 12 months old with 12K miles.
    Do you think this could be true and why wasnt it picked up before?
    The car does pull loads better than before, but this may be due to the astra van 1.7 ive been driving whilst the Signum has been at VX.
    Im off to Edmonton tomorrow so i will see how it drives then.
    Im just dont think that a 120 ECU program would run a 150 engine for over 100k miles before flagging up a fault?
    Woodsta
  1. unknown fault code
    By Dannyboyjosh in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2012, 22:12
  2. unknown fault
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 14th August 2009, 21:30
  3. Unknown fault????
    By bigpaw35 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 19:35
  4. unknown fault/canbus code?
    By Jimbobthegreat in forum Engine & Drivetrain
    Last Post: 23rd January 2007, 00:25
foutcode p0602 vectra c
2006 astra 1.7dti fault code p0602
Opel DTC P0602-0
p0602 vauxhall fault code
vauxhall vectra c fault code p0602
astra 1.7 diesel 2002 P0602
vauxhall astra h p0602-44
Dtc code P0602 opel
po602code
Vauxhall DTC P0602-48
Vauxhall DTC P0602-0
p0602 vauxhall
opel dtc p0602
vauxhall fault code p0602
vauxhall astra fault code 0602
po602 code astra
what is trouble code p0602 for persona
0602 fault code
P0602 - Control Module Programming Error astra g
