Thread: CDTi Cam Belt
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Default CDTi Cam Belt
    Has anyone done a cam belt on a cdti?what are they like to do.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Not physically done one myself but an Indy garage charged £60 labour to do one
    On the back wheel
    Think i will do a how 2 in the new year any objections?
    Leicester
    If anyone has done a 2.0 16v petrol car, it is about the same sort of job, fiddly but not hard.
    As usual the rollers and tensioners should be replaced, but the other item that is a must is replacing the water pump.
    This is the main cause of failure on higher mileage cars. But if the belt system does go pear shaped, fortunatly, it is only the rockers that break and the valves and pistons stay intact!!
    So not a massive job if you do have a failure.
    UK
    Has it been designed to not damage the valves and pistons then?
    Regular Member Craig1985's Avatar
    harwich essex
    Quote Originally Posted by WHOOSH05 View Post
    thought they were chain driven? tbh?
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Seems daft to me what with the DTi being chain, and the CDTi going back to a belt.
  1. CDTI 150 CAM Belt again :)
    Last Post: 10th June 2012, 16:21
  2. Cam belt 1.9 CDTI 150
    By chewy71 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 20:00
  3. Cdti 150 timing belt
    By John LE in forum Engine & Drivetrain
    Last Post: 4th January 2012, 12:30
  4. Timing belt on 1.9 cdti 150?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 10:35
  5. cam belt on 3.0 CDTi
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 19:53
