Thread: vectra only blowing hot air
    Regular Member Alec's Avatar
    Dundee
    Thumbs down vectra only blowing hot air
    hi can anybody help my vectra 2.2 sri heater control will only give out hot air even when you turn it to cold has any body had this problem chears
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Only with my missus !!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Dont know if you have it sorted..
    IF you have AC, its needed to be refilled.. it loses a bit all the time.
    Mine did the same.. it should be refilled every 2 years.
    Regular Member j13hdb's Avatar
    Nottingham
    Open the window ;-)
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    Sounds like it could be your heater control panel thats at fault as it's all electronic. Either that or there could be something stuck in the temperature adjustment flap.
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    I can't wait until I need to cold AC on at the minute no chance.....
    Saw on the news that there's going to be a massive heatwave this summer.... bring on global warming
    lanarkshire
    mines has stuck on heating only too! now how to fix is the next question is it diy able ? maybe a scottish thing lol
    London
    I had the same problem - before you spend 90 odd quid on a new control panel, try the following.
    Remove the glovebox ( 5 torx bolts )
    There are two red levers attached to the white centre console unit - they should move when you turn the temperature control. If they don't the unit that controls this has probably jammed. If this is the case, you can try working it free by unclipping the red lever and try moving it with a screwdriver. It is easier to get to if you remove the lower cover on the centre console in the passenger footwell.
    I'll attach some pictures later.
    Regular Member grumpano's Avatar
    North West
    Red face
    My heater was doing the same thing. So tried the above but the black control box below the red levers would not move. So as a last resort i hit the control box a few times with my screw driver
    And this did the trick
    All workin again now
    Regular Member GoldenWonder's Avatar
    Durham
    Quote Originally Posted by dieselman View Post
    Exactly the same thing happened to mine. Took a few attempts to get the linkage to move but its been fine since (lots of WD40 and a stiff neck!)
  1. Exhaust blowing on vectra c
    By JAMMUR in forum Troubleshooting
    Last Post: 30th July 2012, 21:09
  2. Vectra LS blowing cold air only
    By andy64 in forum Troubleshooting
    Last Post: 23rd January 2011, 18:04
  3. Vectra C blowing cold air
    By 999bruno in forum Engine & Drivetrain
    Last Post: 19th December 2009, 12:40
  4. Vectra GSI Exhaust blowing
    By RoddyKFC in forum Engine & Drivetrain
    Last Post: 21st March 2009, 00:09
vectra c blowing hot air
vectra heating always hot
vauxhall insignia climate control problems
vectra c heater stuck on hot
car blowing out hot air on my vectra
vectra c heater only blows hot
vauchall vectra c hot air on cold
vauxhall vectra blowing hot air
my vectra only blow hot air
my vectra pumping out warm air
my cdti vectra only blows hot air
Heaters only blow hot air on vectra
no cool air only hot on vauxhall vivaro
2005 vauxhall astra only blowing hot air
Why is my heater stuck on hot in my insignia
Vectra heater hotcold sticking
vectra c only blowing hot air
Vectra c heater stuck on hot air
vauxhall insinia air condioning hot
heater 9nly blowing hot air in vauxhall insignia
my vauxhall vectra heater is only blowing hot air
o5 vectra blowing warm air when on full
vectra c heater blowing hot air
vectra hot air with heater off
vectra only blowing out hot air
