Thread: Rubbing noise
    Larkhall
    Default Rubbing noise
    While i'm moving on full lock i keep getting a rubbing noise from the driver side wheel.
    Doing a u-turn in a side street with the window open i noticed it so went round again and it done the same thing.
    I can't really describe it but it's only when on full lock
    Regular Member Stuarty's Avatar
    Aberdeenshire
    If you are running bigger than standard wheels it could be the tyres hitting the inner arch covers,check them anyway as one of the clips holding up the plastic inner may have broke and caused it to drop and is hitting the tyre?
    Larkhall
    The car is on standard VX sri alloys and it does sound like a rubbery-ish noise
    Aberdeenshire
    Dont know what else it could be mate best to put on full lock tomoz and have a feel round the wheel and see if you can find any thing or jack up the car take the wheel off and if it has been rubbing on something u should be able to see rub marks on it.
    Larkhall
    i'll have a look around tomorrow. best bet is probably to take the wheel off
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Splash loads of talc inside the arch and give it a go, any rubbing will show easily then.
  1. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  2. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  3. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  4. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  5. rubbing noise from rear
    By robinhood66 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 16:35
