Thread: parking sensor fitting nightmare !!!!
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default parking sensor fitting nightmare !!!!
    Today i fitted my new irmscher door pins and sill plates and also cisbo parking sensors. I'm not one for cutting corners as i always beleive it will come and bite you on the bot but today i followed the how 2 for the parking sensors, rather than remove the rear bumper i followed the dimensions made sure everything was spot on applied some masking tape and started to drill the holes everthing was going well untill i came to remove the tape from the last hole, it only pulled the paint from the bumper as i peeled it off about half inch square. Totally gutted. Anyway phoned chips away who is coming on wed to put it right. Now they are fitted and they are working perfect so im sort of a happy bunny.
    Warning to others REMOVE THE ****** BUMPER dont cut corners.
    By the way i ordered the dark blue sensors which isnt a bad match for my metro blue vec .
    Regular Member Karl's Avatar
    Sunderland
    the paint came off when you used masking tape?!?!?!?!?
    sounds bad, surely masking tape is the weakest tape around?
    Feb 2007
    Durham
    Never dreamed that would happen.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    was gonna say masking tape shouldn,t do that
    Regular Member Harry's Avatar
    Uxbridge, London
    i don't think it was the tacky-ness of the masking tape that pulled the paint off, the paint was on the edge of the newly drilled hole, and it was weaker.
    and yes...definitely remove the bumper, it saves time marking out aswell.
    Feb 2007
    Durham
    Quote Originally Posted by Harry View Post
    Harry, it was'nt actually at the edge of the hole it was just above and to the right. i think it must have been an area on the bumper where the key was poor.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    I've always used black insulation tape as it's always in my pocket and never heard of this happening but a very handy tip if you was to do it on a daily basis so pretty pointless tip here I guess but is to use a white board maker pen. You can draw all you like on the bumper and just wipe it off.
  1. towbar and parking sensor fitting (notts / derbys)
    By mattsbmw in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2011, 17:01
  2. Parking sensor fitting.???
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 21:06
  3. Supply and Fitting of Parking Sensor HELP
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 08:36
