Results 1 to 10 of 15
Thread: cd won`t eject
    Oct 2006
    spalding
    Default cd won`t eject
    one of the daughter`s cds has become stuck and won`t eject. it plays as normal but i can only listen to "the wheels on the bus" so many times!!! any advice will be greatly appreciated
    Cirencester
    little trick i found is to hold the eject button down for approx 10secs and this resets the loading mechanisism
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    What Stereo, CDR2005, CCR2006???
    Feb 2007
    North west
    Every (non car) cd player has a manual release, a tiny hole that you push say a straightened paperclip into and it releases the disk. If its a car cd without a manual release usually a dealer job.
    Oct 2006
    spalding
    just tried the 10 second hold down, still stuck. model is the cdr2005. sorry, i should have thought to say! is the stereo easily removed?
    Jun 2007
    Right, when i took my 2005 out of my car, i left a CD in the machine.. It was pretty easy to take out IIRC...
    Take the Stereo out, and take the top and back off it, its a T6 Torx if i remember rightly, There are 6 screws i think... Once the back/tiop is off, Look thru from the back and you'll see the CD and the piece that goes thru the centre of it.. I used a plastic ruler to slide in the gently push the centre of the CD off the centre piece thingy... Once its clear the CD should slide out... Put it back together and Bingo.. Mine still works as i sold it too a friend and he has had no problems with it...
    I cant guarantee you wont do any damage to the stereo, Just explaining how i sorted mine out...
    Oct 2006
    spalding
    thanks for that, such a shame i don`t share my 4 yr old daughter`s taste in music. i`ll have a look at removing it when next off work, back again tomorrow night.
    wales
    My wife had a cd stuck her car to get it I used a another cd pressed eject and put the cd slightly into the slot and the cd came out HTH
    Mark
    May 2006
    scotland
    Right, if u have not already got it out, try this. I had this last winter and was due to thermal contraction/expansion. One particular CD would not eject so on a 15 mile journey I made sure the heater was on full heat and the car got nice and warm inside and the CD ejected no probs. The said CD always jammed in the cold so I stopped using it, all others have been OK. The said CD had a slighty thicker profile due to fancy print on it, just maybe this is your problem
    Oct 2006
    spalding
    disc now removed, stereo refitted and code entered. pressed eject without a disc in and it still claims "error cd". the eject parts seem to be the problem,would an alternative cdr2005 from a breaker`s yard work? is radio code for the car or the stereo, i`m suspecting it`ll be for stereo but hoping not. which aftermarket kit is cheapest to still use steering wheel controls, not too fussed about gadgets as long as it plays cds!!
  1. CD70 won't eject sat-nav disc
    By Jebus in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2012, 01:31
  2. CDR 2005 don't eject CD
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 23:19
  3. 2013 wont eject cartridge magazine
    By malk in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2009, 17:37
  4. ccr2006 eject
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 00:20
https:www.vectra-c.comforumshowthread.php36704-cd-won-t-eject
cdr 2005 vdo cd stuck
cdr 2005 error cd eject
cd wont eject cdr2005
cdr 2005 cd stuck
cd wont return in vauxhall insignia
force cd eject vauxhall
remove cd from corsa c
cdr 2005 not ejecting cd
reset cdr 2005 eject cd
cd blocked in vauchall vectra
eject cd from cdr 2005
remove cd vectra c
siemens cdr 2005 error cd
vectra cd player wont eject
how to get a CD out of a Vauxhall Vectra CD player
cd stuck in cdr 2005
how to remove cd from vauxhall cd30
siemens vdo cdr 500 emergency cd remove
vectra mk3 cant eject cd
vaxhaul cd30 hard eject
cd stuck in car stereo opel zafira
cd refuses to eject on vauxhall corsa reg07
Siemens VDO CDR 500 CD stuck or atascado
cdr 2005 vdo cd error
