Results 1 to 10 of 14
Thread: 40" LCD Wall mounts.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default 40" LCD Wall mounts.
    Anyone fitted a wall mount. I has a Bravia 40" for chrimbo . A Sony Wall mount is approx £300. There are some other mounts starting at £60...But can i trust em?
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    if others fit then just make sure your using the correct bolts to hold the wall mount up plus make sure your tv is included in your home contents insurance just in case it crashes to the ground.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Save youre self some money, have a look on fleabay, I got one for about £30, did the job well HERE
    Chester
    No More Nails?
    Our TV is a 37" Samsung. Paid around £150 for the bracket which was probably well over the odds but I went for the over engineering approach which included ditching the supplied weedy bolts and buying the biggest ******s B and Q had in stock.
    The bracket is universal though so if we change brands it can stay in situ.
    Cut the box up to use as a template Steve to make sure it looks right and if you haven't already got one you are more than welcome to borrow my laser leveller.
    This makes it a piece of **** to fit accurately.
    edit: Just looked at the one in Mark's link. Ours is similar to that one but with thicker rails and supports so I'd say ours is a bit OTT.
    edit 2: BTW did you know that Maplins have opened a store on Cheshire Oaks? Brilliant for longer cables such as Scarts, Component leads etc. It's next to Borders.
    Regular Member Harry's Avatar
    Uxbridge, London
    i helped my brother fit his 50" sony to the wall using a bracket from ebay, i think it cost him about 60 quid as the bracket itself was the type that swings out...and even with it fully extended (2 foot off the wall) it still held strong.
    needless to say, alot depends on the base material that you're fixing into...this was into brickwork.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    as above most of the brackets are fine ..........its what your fixing into and fixing with that matters IE dont use inch screws lol
    Regular Member Islander's Avatar
    Barrow-in-Furness
    Try these, will hold a tank..... £65 inc. postage, similar one in Comet £ 250!!!http://myworld.ebay.co.uk/*simon_lee*
    Feb 2007
    North west
    maplins have em for £50 - well up to the job.
    My brother fitted his with a universal, a 40" bravia as well, beware of putting above your fire though, his overheated and he has had to move it, leaving huge bloomin holes in his wall !!
    Feb 2006
    Wirral
    Quote Originally Posted by Bainie View Post
    OH....That's were she wants it!
  1. Wall Paper = Please Help = I've Run Out = Thanks
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 6th August 2011, 20:33
  2. tv on wall??
    By lochgilp in forum The 'Off Topic' room
    Last Post: 25th August 2009, 16:05
  3. Watch out for the wall
    By bill1250 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2008, 09:39
  4. If This Don't Drive You Up The Wall..........
    By Ben H in forum Comedy & Humour
    Last Post: 16th February 2007, 17:33
