Thread: 2.0 DTI Glow Plugs Replacement
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Red face 2.0 DTI Glow Plugs Replacement
    Could anyone enlighten me, I suspect my glow plugs are faulty as the spanner light comes on in the cold, but goes off after a while and doesn't come on if the engine is warm plus it had a full service less than a month ago.Cars done 58K, so I reckon they need changing anyway. But I need to know the part numbers and how to take the plugs out, do I need any special tools, do I need to wtahc out for anything. Any assistance will be appreciated..Is there a how to ???
    11 Post(s)
    Does the car still start up ok from cold? If so, then the glowplugs are probably ok.
    Water in the fuel filter can put the spanner light on. Maybe they didn't change it at the service, or because of the cold weather, it's got some in again.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Yes it starts up fine, but wouldn't the light stay on all the time or whenever I start the car, if theres water in the fuel filter. How would I check ??
    West
    On my old Vec B, when the glow plugs were at fault the eml would come on until the engine had a little bit of heat in it.
    I haven't replaced them on my Vec C as yet, but i am certain they are as easy to change as my previous B, Zaffy dti & Astra dti.
    I don't have part nos. to hand or socket sizes.
    But a deep socket set & ratchet is all that should be needed, it's just like replacing a spark plug.
    Undo the plastic plug connector/cover for each plug.
    Remove plug & replace.
    Its not a hard task, just take care with plugs that are stubborn, you don't want them snapping off or stripping the threads whilst re doing them.
    hth
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    This may be a dumb question, but how does the plastic cover come off. Its like a spark plug lead and the it rotates on the glow plug. I tried to yank it off, but it didn't want to move. Do I need to give it a squeeze to unlock it ? Or is it a specialist tool ??
    Hertfordshire
    Don’t yank the thing !!! You'll break the clips !!!
    There’s little clips on the side, you have to squeeze them and they release and it pops off.
    Try the lead gearbox end first, it's a lot easier to see and get to.
    PS: I am not 100% sure, but I think the 2.0l is similar to the 2.2l, so you might wana read this as well. (particularily post 9 by me)
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    All done, glow plugs replaced and all is good..Many thanks
    Nottingham
    i've just done this, the clips are very stiff (in the cold anyway) so i got an old pair of long nosed pliers, bent in the tips and it made the job really easy, you just apply pressure under the very top of the connector lead
    cleared my spanner light too
  1. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  2. Glow Plugs
    By st2malo in forum Engine & Drivetrain
    Last Post: 10th February 2010, 19:26
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. Glow Plugs
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 17:31
  5. glow plugs
    By darren klershaw in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2007, 19:51
how many glow plugs in a vauxhall vectra 2.2 dti
zafira a2.0 dti glow plugs
vectra glow plug change
how to change vectra 2.0 dti heater plug
change glow plugs zafira dti
doeab2003 zafira have glow plugs
2011 astra 2.0 diesel glow plug number
glow plug change on 2.0 ltr diesel astra
vectra c 2.0 diesel how to fit glow plugs
glow plugs for vauxhall vectra c
vectra c 2.0 diesel glow plug change tools needed
tools needed for vectra c glow plug removal
how do you change glow plugs in a 2.0 vectra
vauxhall zafira 2.0 dti glow plug relay location
how to change glow plugs 2litre diesal zafira
vauxhall vectra glow plug test
vauxhall zafira 2.0 glow plug change
2005 vectra c 2.0 dti glow plug located
replace glow plugs vectra 2.0
whar size are vectra c 2.0dti glowplugs
location of glow plugs vectra 2.0l cdti
vectra dti glow plug fault
change glow plugs vauxhall vectra c
vectra c 2.0dti glow plug top spinning
