Results 1 to 10 of 11
Thread: CDTI Engine temperature ?
    Regular Member dinac_cro's Avatar
    Nov 2007
    Zagreb/Croatia
    Default CDTI Engine temperature ?
    i think that my temp. is way to low .. maybe sensor failure or is it normal that low temperature ?
    let say it never goes over 85 C
    but usualy it sticks below 80 C
    1,9cdti , 150KS
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    Sounds about right mate. Mines exactly the same. I left it running on the drive for 30 mins the other day to see it the spanner light came on and the needle didn't move above 80 and the fan didn't turn on.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    sounds like normal to me.....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Thumbs up temp
    sounds ok,it'll run a little warmer when it's warmer weather as expected.
    11 Post(s)
    Quote Originally Posted by the-wizard View Post
    The thermostat should compensate for the cold weather and stay shut longer until the correct operating temperature is reached. 80 degrees does sound a bit low, but then again I'm more used to petrol engines, not diesels.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Mine would open to just over 80 and then drop back to around 75 when cruising on the motorway........changed thermostat a while ago and it now runs bang on 85 and the cabin temp is a lot hotter as well
    Nov 2007
    Zagreb/Croatia
    hm ..... normal or not then ?
    seems to me also to low , my runs @ 75 C on motorway
    2IamtheStig: maybe that thermostat sending wrong parameters to ECU, and then engine jerks/juddering a bit because that ... maybe u have that problem ? Thermostat is not so expensive, right ?
    A few nights ago I managed to get 15 miles before the temperature gauge even moved!
    After 30 minutes and it was well below normal, however the outside temperature was just below freezing
    Normally I get about 5 to 6 miles, and then it starts to level out between 80 and 90
    Nov 2005
    Somewhere in time
    Nov 2007
    Zagreb/Croatia
    excelent thy !!
    maybe u have catalog number ? :P
  1. Engine Temperature keeps going up and down (2.0 DTi)
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 00:29
  2. 3.0 CDTi Y30DT engine oil temperature
    By Celes in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:48
  3. strange 1.9 cdti 8v engine temperature goes up and down ???
    By lollypop in forum Engine & Drivetrain
    Last Post: 15th April 2009, 23:00
  4. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
  5. Engine temperature
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 25th July 2005, 16:10
