Results 1 to 10 of 13
Thread: power loss when driving in a 2.0dti 53reg
    wolverhampton
    Default power loss when driving in a 2.0dti 53reg
    hi can any one help i have a 53plate vectra 2.0 diesal with only 37k done when i drive above 80 there is a loss of power and the service light i belive comes on (its the car symbol with spanner showing) i have to switch it off then on and its ok,its getting worse now i cant go above 88mph. plz help what do i need to do, not a mechanicall man.
    ireland
    Hay mate was just about to post the same thing it will be a boost valve or pipe mate of mine works at cars and has told me its a common fault.
    My problem is the car is also using a lot of fuel does anyone know if this would be linked to the boost valve going in the car???
    May 2007
    Grays Essex
    has your air filter been changed do you have smoke at those speeds?
    wolverhampton
    Thanks Guys I Have No Smoke All Is Fine Its A Loss Of Power Only And Service Lights Come On To0 Get Rid U Have To Stop Swich On/ Off Then Its Ok But U Cant Increase Speed Rapidly Then It Starts Again
    How is the car when you give it some beans away from the lights matey?
    It's a hard one to diagnose to be honest, it could be a number of things. As the car's jumped into 'limp home mode' you'll have a fault code that can be read at the dealership.
    weymouth
    Ive had a similar problem and posted on another thread. Took my car into an indy with the latest computer tech and they said that there was no fault code stored. Apparently the code is being wiped out when I resart the engine. I have to take it back on Friday for another check. They say that I may have to drive with the computer connected and hope the fault happens during that time. This will then according to the garage display the fault. Anyone got any suggestions??
    Is this an independant garage matey? If the engine management light has come there will be a fault code stored matey.
    I think I'm right in saying that any fault older than 50 engine starts (not sure if this figure is right) will be wiped from memory.
    weymouth
    Yes it is an andependant garage. Im going back inan hour. I will let you know any outcome.
    Belfast
    My Astra never recorded a fault code, same engine. It would light the EML when slowing down for traffic lights. Even with the EML still on, the Tech2 wouldn't read the code...
    weymouth
    Ive been to the garage. They connected the computer and I drove around for an hour. Eventually the car started to splutter, spanner light on, I slowed down and stopped and the engine then started to tick over as normal with spanner light off. I pulled away and its back to normal!!! Still no fault code recorded. Ive spoken to a mate of mine who is a mechanic and he is recommending a new fuel filter to start with. Any advance on this from anyone??
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Loss of power - 2.0DTI
    By mcally in forum Engine & Drivetrain
    Last Post: 4th November 2012, 18:55
  3. Loss of turbo whilst driving
    By digitalinkjetman in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 14:51
  4. 2.0dti power?????
    By stubopvectra in forum Diesel Engine related
    Last Post: 21st February 2008, 20:24
  5. Temporary loss of power 2.0dti
    By bran.c in forum Engine & Drivetrain
    Last Post: 5th August 2007, 22:17
