Results 1 to 3 of 3
Thread: Disconnecting the Battery
    Kent, UK
    Default Disconnecting the Battery
    I need to disconnect the battery, is this going to cause a problem for anything or am I likely to get an alarm in my face?
    TIA,
    Adam
    [Ex]Admin Duncan's Avatar
    iirc - if you disconnect the negative terminal within 30 secs of turning off the ignition (before the immobiliser kicks in) it won't set off the alarm. When you reconnect the battery make sure the ignition is turned off.
    HTH
    Kent, UK
    Thanks Duncan, it worked!
    My nice Nokia CK-7W is all installed now! A great toy that you can't even tell is fitted unless you notice the microphone up by the interior light or the button by the steering wheel!
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2009, 17:27
  2. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  3. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  4. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  5. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
