Thread: Central Locking problem
    Telford
    Default Central Locking problem
    Can anyone help? My Vectra estate 2001 will not lock or unlock by remote.
    I press the fob and light on the fob flashes as do indicators but have to unlock drivers door manually - even when I unlock other doors manually both the passenger and one rear door will not open..!
    Telford
    Just to add further, I have changed the battery in the fob - please can anyone help?
    11 Post(s)
    Try re-sync'ing the fob to the car, as per the handbook info. I know your fob doesn't look like the one in the picture, but it's the same proceedure.
    11 Post(s)
    Hang on a mo, if the indicators are flashing when you press the fob, it means it is working. Try checking the central locking fuse hasn't blown.
    Telford
    Checked fuses - all ok. Is their a relay I cn check and if so, which one..?
    Telford
    Smile
    All OK now, turned out to be multi-plug in door hinge, took apart, cleaned, sprayed with WD and hey-presto!
    Thanks anyway Big Dave!
    11 Post(s)
    Glad you got it sorted.
  1. Central Locking Problem
    By hairymark in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2013, 14:41
  2. Central locking problem
    By Badger59 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 21:47
  3. 1.8i 16V T Reg Central Locking problem
    By Mytac in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2008, 10:12
  4. Central locking problem
    By Hideous in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2007, 11:29
  5. Central Locking Problem
    By Penfold in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2007, 22:20
