Thread: advice on earth strap
    Regular Member teera2uk's Avatar
    Oct 2007
    Lincs
    Default advice on earth strap
    Hi guys someone asked me to change their timing chain on a 2.2 sri which managed to jump a couplke of teeth and do the inlet valves and guides
    long story short my part of the job went perfect but he stripped and replaced the head after replacing with new parts etc etc but he showed me that he is left with a braided earth strap about 6" long 1" wide with 6mm eyelets at either end suitable for 10mm bolts anyone know where this goes my veccy is a cdti so top end is totally different
    any help much appreciated
    member of the smoke patrol 230bhp+
    as long as you do earth the engine it's not going to be a prob
    or you can make-up or buy a longer earth and bolt it down to where you want to
    Regular Member rickyroo's Avatar
    shropshire
    Attach it directly to your battery earth strap or onto anywhere upon the chassis would be good, don't forget to sand down the paint though before attaching as paint is an non conductive material.
    Oct 2007
    Lincs
    theres some confusion here it is only about 6 inch long and dont go to the battery wether it is from head to inlet or something im not sure
    Full Member Big Sig's Avatar
    It wil go from the block to the inner wing somewhere. Sorry but I can't help with exactly where.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    hello mate if you call that strap 6 inches you need to get a new tape mesure !!! it goes from the 13mm bolt that has a ten mill nut on the end that is on the back of the rocker cover top right corner just bellow where the dis plug is and slightly towards the back of the car the dis loom and egr loom mounting braket also fits there then it goes to a bolt that has the radio surpresor on it and is held on with a 10mm bolt .that is just bellow it and just above the exurst manifold ..go to www.z22se.co.uk if you have any problems finding where it goes
  1. Strap hanging under car
    By VectraMikey in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2013, 10:11
  2. earth strap z22se
    By nathy1 in forum Engine & Drivetrain
    Last Post: 21st February 2012, 22:55
  3. clunking door strap
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2011, 12:52
  4. Check strap
    By a6lns in forum Bodywork & Interior
    Last Post: 21st August 2011, 14:23
  5. Check Strap
    By Neil in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 05:47
vauxhall vectra c engine earth strap
