Thread: coolant
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Default coolant
    coolant light's come on twice in the last couple of days, can I top it up with water or do I need the same yellow liquid? (I'm assuming the coolant is the yellow fluid in the clear plastic ball thingymajig... )
    member of the smoke patrol 230bhp+
    for topping it up id say water is o-k to top up
    Aug 2007
    London
    cheers, I'll give that a shot tonight.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The proper vx stuff is only about £2.50 is a ltr. If you keep topping up with water its going to dilute. Also with that ally head you have in your YH make sure if you go down the antifreeze rout get the proper stuff as 2.2 heads have been known to corrode due to the wrong type antifreeze.
    also, if it's using coolant that quickly, get where's it going investigated quickly..
    Aug 2007
    London
    Quote Originally Posted by rushy
    cheers
    I don't think there's a leak, I'll top up with the the real stuff as per rushy's post, and get it checked in the new year.
    If the light has come on twice in the last few days and it's dropped coolant right down, then it's not good.. if the level hasn't moved down, then it's just the sender as a very good guess ( not unknown) ....for a cheap first fix, change the pressure cap
    Aug 2007
    London
    yeah, it hasn't gone by much, just about 5mm below the fill mark.
    pressure cap..
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
