Results 1 to 10 of 23
Thread: A filler pipe too far!!!!
    South London
    Default A filler pipe too far!!!!
    Just filled my 2.2Dti up at a tesco garage with Esso pumps.
    The filler nozle slipped easily into the fuel filler pipe, BUT, would not not come back out.
    After much swearing, pulling, pushing and nearly yanking the filler pipe and tank out of the car I managed to free it. The flap covering the end of the filler pipe is now not visible, I think it has bent back on itself.
    Anyone else had this happen and how did you free the nozle?
    Needless to say the forecourt was full of cars and I caused quite a hold up in the queue.
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Quote Originally Posted by FRANKA View Post
    yeah I've had this happen to me too , it gets stuck on the ribs on the nozzle, the way to get it out is twist the nozzle so it's straight ,the best way I've found for filling up from the opposite side is pull the car up so the boot is in-line with the nozzle, should have plenty of slack if need
    stupid ribs grrrr
    North West
    i done the exact same thing,bent and eventually snapped off the filler cover
    A short while later i had a water leak under the bonnet and engine temperature went sky high.
    Took it into vauxhall,good job it was still under warranty they fixed it 4free.
    I think some of the metal bits from the filler cover must have made their way in to somewhere and caused the leak
    Keep a bottle of water handy
    member of the smoke patrol 230bhp+
    yes there is a big long list of use that have done the same
    Regular Member heaton_uk's Avatar
    Wigan
    I used to work for Total garages and the more modern pumps are worse for it. The trick is to turn the pump 90 degrees, and gently ease it outwards. Its actualy a very bad design on vauxhalls behalf we were told. One time we had a fire engine down to cut the pump hose, and the car went off on a tow truck. Its classed a potential risk of explosion by forcing it the pump out as it may cause a spark.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    happened to me too, twice!
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    At least it doesn't happen when I'm on me bike
    Quote Originally Posted by chrisgettings View Post
    I'm on it!!!!
    Regular Member Lightboy's Avatar
    May 2007
    Reading, UK
    Exactly this happened to me on the way to Scotland a couple of weeks ago. Nightmare, took me 25 minutes with a screwdriver to get the pump out, the metal flappy bit came off and slid into the tank with the crap wire spring clip type thing.
    So now I'm driving a veccy with metal stuff rattling round my petrol tank. Not happy.
    Guess the only way out is to whip the tank off, empty the metalwork and get a new inlet pipe?!
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    Quote Originally Posted by al21784 View Post
    Class
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. 2.0 diesel fuel filler pipe
    By BIGPGR in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2012, 17:26
  3. how much is a filler cap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 22:14
  4. Wobbly Fuel filler pipe
    By cheekylemon in forum Bodywork & Interior
    Last Post: 28th September 2007, 00:20
  5. Filler Cap
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2005, 08:07
