Thread: Heater Motor
    Hampshire
    Default Heater Motor
    Hi Everyone,
    I have had the pleasure of the resistor pack going. main stealer said it will be the motor and will not replace the resistor pack. the resistor pack's thermal fuse has 'popped' and Maplins do them for 0.89p so will be getting one of them
    The main thing now is I want to get the motor out to see if it is rusty.
    been crawling around in the footwell for the past hour and can not figure out how it comes out.
    anyone any ideas. I did try to search but could not find in instructions
    Merry Christmas
    RichPu
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Back in a tick mate, might be able to help, no promises though. LOL
    Vehicle : SRi
    Mileage : 137000
    Right mate, not much help as all the instructions say is that you need to take out the passenger air duct, remove inner panelling for lower centre right instrument panel padding, remove resistor and wiring harness. Then there are 7 bolts that need to come out plus 3 clips and that's it.
    Hampshire
    Hi Rushy,
    thanks for that.
    took me a while to find all the ones that needed to come out.
    finally got the motor out. was not rusted but was a little stiff to turn. so oiled it and ran it on the bench for a while made it a lot easier to spin
    I think the problem was the switch was set to 1 and when you started the car there wasn't enough power to get the motor spinning and the resistor over heats and pops the thermal fuse.
    fingers crossed a new fuse and it will now work
    I have taken a picture of the housing and will post this up once I change the size etc
    cheers
    RichPu
    Vehicle : SRi
    Mileage : 137000
    VX field remedy states you need to drill a little hole in the bottom of the housing to stop any water build up. Also check drain isn't blocked under your scuttle panel as that is the cause for the water ingress in the first place.
    Regular Member D-S-Dave's Avatar
    Jun 2006
    Home init
    Quote Originally Posted by richpu View Post
    Hi Rushy,
    thanks for that.
    cheers
    RichPu
    A while ago I know, but do you have that picture?
    Hampshire
    Here you go Pugster, I have tried to highlight the 7 bolts
    regards,
    RichPu
  1. Heater Motor
    By barnes61 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2011, 17:46
  2. heater fan motor
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 20:08
  3. Heater motor fan
    By hucknallshell in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 20:27
