Thread: help please engine fault light
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    Default help please engine fault light
    help me please, ive got a 53 reg 2.2 sri veccy, 37,000 on the clock. and been out in it to day, and the engine fault light has came on, and wont go out, it drives fine, no probs what so ever
    if you put your foot down it goes like usal. ive had it 4 months had no probs, but the light has came on, drove bout 10 miles with it on.
    no garages are open now till thursday i think, and im ment to be going down south in the next few days, checked oil, water, everything, no leaks or nothing, any ideas?
    thanks
    Nov 2007
    telford
    any one?
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Can you clarify the light that's on? Is this in the rev counter with the spanner through the car (engine management), or an "engine" type symbol elsewhere on the dash.
    The spanner through car, if on, I'd have thought you would have noticed a performance difference as this should be in emergency running mode. The other one I can think of is the emissions light. Check your handbook if you can, as from memory this is OK to use unless flashing, although there is a danger of damage to the cat.
    Jul 2006
    Mexico
    carefull with the cat. and for the solution you have to plug the car and check fault codes to see what`s going on ASAP HTH
    Regular Member rickyroo's Avatar
    shropshire
    I'll have a look for you you mate p.m sent.
    shropshire
    Question for you beefycol, where did you get your fuel regulator kit from?
    Nov 2007
    telford
    Quote Originally Posted by rickyroo View Post
    hi all thanks for the comments, it went off now, just come back from down south. had no probs no light or nothing. strange,
    rickroo
    i got it off ebay the adjustable ones, there bout 30 quid aint put it on yet havent had chance, need to find out the pressure of the standard one, then going to set it to bout double its standard pressure
    Nov 2007
    telford
    i took the ecotek valve off to it was annoying me
    shropshire
    I've got the same regulator but the problem is the old regulator is cyclindrical and the adaptors supplied are not good enough!
    We can converse when we meet.
    Cheeers bud
    shropshire
    sorry forgot standard pressure is 3bar mate.
  1. Replies: 2
    Last Post: 10th September 2012, 19:09
  2. Engine fault light on / Juddering when hot
    By Angelchops in forum Engine & Drivetrain
    Last Post: 17th September 2011, 19:16
  3. 2.2 petrol LS engine cuting out and emmissions fault light on!
    By affirmation in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 15:00
  4. Fault light comes on engine dies of death
    By mcfly0009 in forum Engine & Drivetrain
    Last Post: 16th April 2007, 17:52
  5. Reset Engine Fault light
    By jamesr in forum Engine & Drivetrain
    Last Post: 13th December 2006, 11:47
