Thread: Xenon lights too low
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Xenon lights too low
    This is probably in the wrong place but here goes:
    The Xenon dipped beam on my 02 GSi seem very low. I know there's no manual adjustment under the bonnet but I've had other cars with Xenons (Octavia vRS, Pug 406) and their Xenons were the dogs. Even my 1996 Rover 800 Turbo Coupe with standard bulbs is better than the Veccy. As an example, unlit B road - Rover 65mph, Veccy 40mph at a push, yes they're that bad!
    I'm also aware that it's got a self levelling system within the Xenons (you see it testing itself when you switch the lights on) but surely they shouldn't be this low.
    Cheers guys a nd a merry Xmas.
    SOMERSET
    Hi GTR1000, You can change the height yourself. I lowered my car a while ago, the nose of my vec was lower at the front so at night on my drive i switched the lights on and on top of the lights(unit) are a large i think plastic phillips screw head and slightly turned one way or the other to raise them. You only need to move the screw a tiny bit and the safe leveling will carry on as normal. Remember to have the passenger side a tiny bit higher than the drivers side so not to dazzle on coming drivers.
    I hope i have explained this OK
    P.S Make sure you can see the lights against a garage wall or something to see how much they are adjusted by.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Thanks Pimm, will give it a go tonight if 1) it's not peeing down and 2) it ain't too ****** cold.
    Many thanks mate.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Have done the adjustment - it was an allen key screw that I tweaked, not Phillips, that I tweaked.
    Many thanks M8, lights now doing what they should do.
    SOMERSET
    It does feel better when you have correct lighting at night on darker roads.
    Top result
  1. XENON AFL lights
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2012, 11:43
  2. My new xenon lights before/after
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2010, 10:09
  3. xenon HID lights
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 10:05
  4. Xenon Lights...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 12:15
  5. vxr xenon lights
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2008, 19:46
