Results 1 to 10 of 13
Thread: Diesel fumes entering cabin
    Regular Member matt_vec2007's Avatar
    Northamptonshire
    Default Diesel fumes entering cabin
    Hi everyone, finally got my Vectra C, its a prefacelift 1.9CDTi Sri 120.
    Love it to bits, comfortable, great handling, quick enough.
    One slight problem - there are diesel fumes entering the cabin (burnt diesel like being stuck behind a smokey old Peugeot!) - I see this seems to be a common problem, is it a cheap fix? Do Vauxhall repair it under warranty? my car is just 3 years old and has done 78k.......
    Please someone help!
    Matt
    I had the same and it was diagnosed as a cracked exhaust manifold. The car was still in warranty so all was good.
    Your car is just out of warranty though isn't it, so ask Vx customer services if they'll contribute as it is a known problem.
    FYI - a faulty injector venting fuel vapour into the engine compartment can also smell like diesel fumes too. I had this too!
    It's a alarmingly common fault...there are quite a few places it could be ranging from a cracked manifold ( as above) to EGR link pipe failing, exhaust gaskets failed, cracked turbo flanges......
    it needs to go in to a dealers for investigation first, then you can decide if to get it repaired there or not..
    Oct 2006
    Yorkshire
    Default fumes
    i have had the same problem - leaky injector seals
    Supposedly now fixed
    Northamptonshire
    sh!t it does sound common! Any ideas what sort of cost I am looking at?
    Northamptonshire
    booked into my local dealer now in Market Harborough, sounds like I get the pleasure of a Meriva for the day - doesn't seem a very fair swap to me!
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Quote Originally Posted by matt_vec2007 View Post
    Did u find out what it was in the end, coz im having the same problem?
    Northamptonshire
    it was faulty injectors/seals, about £400 to get the offending one replaced......
    good luck
    Malton
    Arse, mine is doing it too
    G
    Malton
    If it was a leaky injector wouldn't it be spraying diesel all over the engine bay - i.e. you'd be able to see it?
    G
  1. 1.9cdti Diesel fumes inside the cabin
    By kingarthas in forum Engine & Drivetrain
    Last Post: 23rd March 2013, 13:26
  2. diesel fumes in cabin!! now sorted with increased range!!
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2011, 20:04
  3. Fumes Entering Through Vents
    By s-owen4 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 17:36
  4. Fumes in the Cabin
    By bennyk in forum Diesel Engine related
    Last Post: 11th December 2007, 13:54
  5. diesel exhaust fumes in cabin
    By marky2027 in forum Engine & Drivetrain
    Last Post: 19th November 2007, 20:52
