Results 1 to 10 of 14
Thread: range
    Regular Member cdms811's Avatar
    Newcastle
    Default range
    what do you trust most. fuel gauge or trip computer?
    Regular Member mac12's Avatar
    Nov 2007
    greater manchester
    i always try and fill up within a mile or two when the trip computer says 30miles left,never had any problems so far (touch wood)
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Fuel gauge is quite good on my new one. Once it gets past that sticky point at the top down to the 3/4 level, I'm very confident in it's readings. Most times when I fill up it's as good as bang on but I don't like to let it fall low for any period of time, I always top it right up.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by cdms811 View Post
    Fuel gauge; the trip computer depends to much on the fuel consumption during the last period - it is only accurate if the consumption is more or less constant: you can have big surprises if you have driven long time at a constant speed and end up in an enormous traffic jam
    Larkhall
    It was the computer for me until tonight. Had 20 miles left in tank and put a fiver in. Range didn't change even when the fuel light went off. It got down to 6 miles until it sorted itself out and went up to 48........
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If you fill your tank right to the brim and then fill up again when you are dangerously in the red - which according to a thread on this forum is half way through - check the OBC for the amount of fuel you have consumed, that way you will know when to fill up for sure. This is because the OBC measures the flow rate of the fuel.
    But to answer your quuestion, trust the range meter for the reason I stated above regarding the red zone on the fuel gauge!!
    Gazza4
    Jul 2006
    Yes, the OBC does measure the flow rate of fuel through the injectors, BUT it's only as accurate as measuring the weather with a bit of string.
    Virtually every time I fill up the trip computer tells me I've used more fuel than the tank can actually hold.....
    Fuel gauge for me every time. Fill up when the light starts to flash and I know I've got about 10 litres left.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by parapaul View Post
    Amazing the 21st century and no car make - i can think of has invented an accurate way of measuring how much fuel a car has.
    Gazza4
    Chester
    Definiatly the fuel guage. No contest TBH
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Trip computer...I can only dream about a trip computer!!!
    It's fuel gauge or nothing for me
  1. Range??
    Last Post: 31st July 2012, 12:54
  2. Just the range pls........
    By Whisky in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2011, 20:39
  3. Range!!!!
    By ianvilla1 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2009, 12:37
  4. Range
    By Atomic in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 18:20
  5. Range...
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2008, 12:13
