Thread: Tyre pressures
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Default Tyre pressures
    What is the recomended tyre pressures for the sri cdti running 215/50/17s goodyear ncts have been told a few different figures can anybody clarify the correct one for me please.
    Cheers stuart.
    Jul 2006
    IIRC its 32 front & rear, 36 for load/speed.
    HTH
    Aberdeenshire
    Ok cheers bud thought it would be around that,Kwick fit told me that it was 42psi all round thougtht that was a bit high?
    Jul 2006
    flipping heck! the Astras we use at work run 42psi all round on 17's, but they carry a couple of hundred kilos of clobber in the boot and generally go fairly quick....
    ....so will your tyres at that pressure!
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    32 all round... or 34 /36 for rears under load..
    32psi sounds a bit low, but its in the hand book. Rule of thumb is twice the rim size. I run mine at 40/38 but then its got a massive cast iron lump in the front!
    ^^^^ to be honest at 32/34, people have said your tyres look a bit flat!!..
    40/38 seems high though... would get a lot of uneven tyre wear at that...
    mine at 32/34 have lasted at least 20k and even tyre wear all round for f1's so vx must be doing something right
    Aberdeenshire
    Cheers for the response guys did think that 42 was a bit high lol
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
