Thread: 1.9 Diesel, what to look for?
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    Default 1.9 Diesel, what to look for?
    i'm going to look at 2 1.9 SRIs tomorrow on 56 plates.
    what should i be looking for specifically.
    any regular faults or hidden minefields?
    thanks.
    Regular Member mushy2007's Avatar
    Liverpool
    Where you going for them?
    I have a very good contact at VX derby road if you want something specific sourcing.
    Oct 2007
    wirral
    Quote Originally Posted by mushy2007 View Post
    there's 2 parked up at the local dealer.
    they're identical spec and the regs are only a few letters out.
    i'll get a good deal as i know a few people.
    thanks anyhow
    my vec b has had it's day as it's got loads of engine work needed.
    so i've near enough decided that a new car is the way to go rather than spend stupid money on a worn down motor.
    Jul 2006
    OK...on the 1.9 CDTi, known faults include...(and i'm sure others will add to this list)
    Inlet manifold
    EGR valve
    Swirl valve
    General Vec C faults include
    Wiper linkage
    Wiper motor
    Heater fan resistor
    Rear shocks
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Definatly check :
    the springs and shocks
    the banana links at the back
    front and rear bumpers for bangs
    oil leaks around the rocker seal and on the rubber pipes in that area
    oil leaks at the back of the engine
    security of the air hose onto the inlet manifold
    aircon heat exchanger for heavy stone damage and check it works
    exhaust security
    turn it on and listen from the outside as it is well sound proofed
    Don't except it with NCT5 tyres!!!!
    check the space saver tyre and the tools
    operate everything!!!
    then tell them you don't think it's in as gooda nick as the other one you've seen and see what they will offer you.
    Oct 2007
    wirral
    you've been most helpfull
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
