Results 1 to 10 of 16
Thread: New tyres and steering out
    Default New tyres and steering out
    Hi all and a Merry Xmas, recently had 4 new 225/45/17 Goodyear Excellence fitted, tracking was checked but was spot on, so no adjustment needed, but my steering wheel is now about half an inch off centre to the left, just wondered why this should happen.
    Full Member Big Sig's Avatar
    The only way that would happen would be if they have altered the steering geometery with the steering wheel not centred.
    May 2007
    Grays Essex
    they must have started to adjust your tracking and then given up if just one side was adjusted then this would put your steering wheel out of line you can have this corrected by moving one track rod out a little and the other side in by the same amount (mark them first) this will change the position of your steering wheel in relation to your steering rack
    Nope they didn't do any adjustment at all, i watched the whole process. I wondered if upgrading from 215 to 225 would have made the difference
    May 2007
    Grays Essex
    are they directional tyres? has one been fitted wrong way round?
    Nope mick, they're goodyear excellence can go anyway
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Try swapping the wheels front to back. I had exactly the same and changing them over cured it for me.
    I'll give it a go fil, but why would that make a difference when all the tyres are new and the wheels are all identical, im confused
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    The way it was explained to me was......
    imagine the tyre in the mould, if the tyre has just a little amount of extra rubber on one sidewall then it's not symetrical.
    Now (i hope this comes over correct) when the tyres are put on the rims, if the "heavy" side is facing outward on the passenger side but inward on the opposite side (or vice versa), this can throw out the steering wheel 'centre'. This is presuming the tyres came from the same mould.
    This was explained to me by a guy who worked at Goodyear in Wolverhampton, so i presume he knows what he's talking about
    Unsure how this affects a directional type tyre though !
    Did you understand ??????
    Very good, thanks for that, i'll try a bit of juggling about then
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. Tyres and steering
    By davidj387 in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2012, 23:06
  5. Replies: 6
    Last Post: 13th March 2011, 10:47
