Thread: light seals
    Warwick
    Question light seals
    rear light seal has a lot of green muck in it and seems to be getting steamed up now and again. Also top corner of windscreen has a big white blodge in it, looks like the seal has gone here aswell. anybody had similar probs before
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    With regard to your windscreen, if it's a white milky sort of blob then it's caused by the windscreen starting to de-laminate.
    A laminated windscreen is two pieces of glass presed together with a thin flexible plastic film between the two sheets.
    After time moisture can start to get in between the layers causing the plastic part to go white.
    You will be able to get your screen replaced under your insurance, normally only costs £50-£60 and wont affect your no claims.
    You need to get it done fairly soon as the windscreen is a major part of the structural strength on modern cars. The windscreens are bonded in to, effectively form part of the body.
    Warwick
    thanks, it does sound like youve described. car is only 8 months old. hopefully the dealership should deal with it
    Feb 2007
    In that case then I would be expecting a replacement under warranty..
  1. Headlight seals
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 02:03
  2. Injector seals 2.0 Dti
    By bigmac in forum Engine & Drivetrain
    Last Post: 9th October 2010, 09:32
  3. caliper seals?vxr..
    By Dose in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2010, 12:23
  4. driveshaft seals
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2007, 00:01
  5. Better than clubbing seals?!?!?!?!
    By Mrs D in forum Comedy & Humour
    Last Post: 11th October 2005, 09:57
vauxhall signum rear light seal
