Thread: Replacing Brake Discs And Pads Help!!!
    Regular Member dti owner's Avatar
    dover
    Vehicle : SRI
    Engine : 1900
    Mileage : 180000
    Smile Replacing Brake Discs And Pads Help!!!
    This Weekend I am going to replace all my brakes, I have the front and rear brake discs and brand new pads, I have the tools needed, But I havent got a clue. Can anyone give me a step by step guide on how to change both front and rear brakes please, and i know that the front are different to the rear apparently. Thank You
    All in the how-2 section matey..
    http://www.vectra-c.com/forum/showthread.php?t=15092
    and
    http://www.vectra-c.com/forum/showthread.php?t=15091
    to replace the discs, once the caliper is off, and the pads are out, you'll need to remove the two torx bolts that hold the caliper carrier on.. these will be very tight ( loctited in) so will need a big bar to help you..the rears you should be able to get the disc off by knocking if off the hub and it should thread out of the caliper carrier. As ever, sand the hub flange up to remove any rust before mounting the new discs, and degrease all surfaces of the new discs before fitting them to the car ( use brake cleaner spray).. wire brush the caliper carriers, and replace with loctite on the bolts.. torque up to FFT.. ( 180Ft lbs) then just reassemble, as per the how-2's....
    Feb 2011
    bedfordshire
    I was about to change the pads on my 03 1.8 veccy and noticed heavy uneven wear on the outer sides of the pads. After inspecting the discs I found they were in a very sorry state with a big lip around the outer edge protruding about 10-20mm inwards
    Anyway, does anyone know the size of the spanner/ratchet I need to remove the star headed (torx) bolts that hold the caliper on?
    thanks, Tony
    11 Post(s)
    Quote Originally Posted by tony_b View Post
    thanks, Tony
    It's mentioned in the how2 section.
    Feb 2011
    bedfordshire
    God I'm blind! how did I miss that? Thanks and in case anyone else is looking for the how to thread on changing the discs its here . .
    http://www.vectra-c.com/forum/showthread.php?t=42093
    Apr 2011
    midlands
    hi i noticed you said you are doing the rear also.... dont do what i did and said to the mrs its a five min job!! just start dinner and i will be back in a bit!!..(54plate dti)
    not sure if you know (i didnt) that when you push the rear caliper piston back in you have to rurn the piston at the same time you push it back. now you can do it two ways one.. use two pairs of grips and turn and push at the same time or do what i done and found someone whe had the right tool to do it.. (oh and just so you know my dinner was cold when i got the job done)
    Feb 2011
    bedfordshire
    Don't get me started on the rears! I done the rears a while ago and boy what a pain they were! First i never realised i needed the wind back tool until I had the calliper out. Then when I ordered the tool it was the wrong size as the veccy c if different to most other vauxhalls and it was a real pain finding the right one. Then, just for good measure, I ruined the thread in the calliper for the bleed nipple and had to replace that as well All in all nearly 2 weeks but if I done it again, with the correct tools to hand, less than an hour ;-)
    Oddly every used veccy I have bought needed new front discs for one reason or another
  1. Replacing Discs/Rotors to Pads Ratio ?
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2010, 07:31
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. brake pads and discs
    By howd3y in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2009, 15:12
  4. Replacing Brake Discs - new caliper carrier bolts?
    By markconlen in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2008, 23:32
https:www.vectra-c.comforumshowthread.php36267-Replacing-Brake-Discs-And-Pads-Help!!!
vectra c rear discs
vectra brake disc and pad removal what size torx required
vectra c brake disc change
problems when changing front brake discs and pads on vauxhall vectra 2005
changing pads on vectra c
vauxhall insignia brake pads and discs
vectra c brake pad replacement
vectra c rear brake pad change
vauxhall vectra rear brake pads and discs replacement s
tools needed vectra c brake disc change
replace brake discs on vectra
2008 vectra rear disc replacement
vectra c rear brake pads
vectra c changing front brake pads
vectra c rear disc replacement
changing front brake pads on 2004 vectra
vauxhall vectra c what brake pads do I need
vectra c front discs and pads
how to change vectra c front brake pads
how to change brake discs and pads on vauxhall vectra
rear brake disc replacement vectra c
how to change front brake pads on insignia
rear pad and discs vauxhall vectra c
vauxhall vectra c brake change
