Results 1 to 10 of 20
Thread: water level keeps going low
    eng
    Default water level keeps going low
    iv got a 03 plate vectra and its been fine until recently the water level went low and the sign came on, so i put more water in but now it just keeps going low wot can problem b
    I assume you mean coolant level
    This is the first sign of a blown head gasket, sadly
    Get the engine warm, then switch off and listen for bubling noises
    Get a sniff test done at a garage and check for mayo under the oil filler cap
    Jul 2006
    Mexico
    First, check if the oil level is not rising or if you a re getting some sort of milk shake look like coolant on the expansion bottle.
    Check for any visilble leaks, if the sign keeps showing even without the need of coolant you have then a faulty coolant level sensor.
    HTH
    EDIT..
    You might drop by at a dealer or independant garage so they make a pressure test....is what has to be done on this cases.
    Preston Area
    this happened to mine as well.. the stealers pressure tested it and there were no leaks, but the water still vanishes from time to time
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    ? water pump seal? any water under the car? if it is, it will get worse quickly!?any water in the oil?
    Right...What engine is it? manual or automatic gearbox?..
    It could be something as simple as a failed pressurecap or it could be something far more serious..
    how much water is it using, and how quickly?
    eng
    its a 1.8 manual, my uncle bought summat from garage and put it in the with the water and since then there has been no leak
    Jul 2006
    Mexico
    I know I have a different engine but this might help......
    http://forum.vectra-c.com/showthread.php?t=35737
    Quote Originally Posted by fizler316 View Post
    sounds like he's put some 'radseal' into it....it's a short term fix..
    it needs a pressure test on the cooling system to see where it's going, then a permanent fix..
  1. Oil light and water level light on and off :S
    By Wrig in forum Engine & Drivetrain
    Last Post: 22nd August 2012, 15:34
  2. Phantom Low Level Water Warning
    By Mawbs in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2012, 19:06
  3. Radiator water level light?????????
    By jase44 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2009, 20:25
  4. Water level warning on cold mornings
    By SignumPhil in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2006, 14:12
