Results 1 to 10 of 13
Thread: noisy car
    Regular Member mac12's Avatar
    Nov 2007
    greater manchester
    Default noisy car
    since owning my 03 vectra for 6 weeks there is a constant noise inside the car from the wheels/tyres, so i took it into the dealers that i got it from and was told that"alot of vectras do it and it was normal".
    when you have the stereo on you cant hear but as soon as you turn it off theres a constant droning/wheel noise from the rear of the car.
    the tyres on the car are michelin primacy hp on the front 215/55/16
    the rear are drivers side pirelli p6000 215/55/16
    the rear passenger side firestone firehawk tz 200
    all have between 6.5 and 6.0mm
    has anyone any idea if it could be the rear tyres that are the problem because the front seems fine.
    dont want to just change the rears really with good tread on as they are still an exspensive tyre only to find the noise is still there.
    really annoying ive never had this much noise inside a car before from the tyres/wheels.
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    Quote Originally Posted by mac12 View Post
    on 4x4 tyres with lots of treat they make a funny noise
    has a bearing gone? happened to me on a old car, kept getting louder n louder the replaced it and it was fine
    Nov 2007
    greater manchester
    i thought bearing but when it went in to the dealer he said everything was fine.(if they bothered to look that is) it only happens when you go above say 10mph, its like being a kid again and having lollipop sticks in my spokes.
    i think its tyre related as you can hear it droning round and round as the wheel is in motion.(very annoying)
    i know you really want the same brand tyre on each wheel or at least the same 2 the on back and the same 2 on the front but ive had different make tyres on different wheels on other cars without any noise.
    Jun 2007
    Black Country
    first thing i would do is get 2 same brand tyres on the rear, 2 different ones can cause a lot of noise
    Regular Member BigDeek's Avatar
    May 2007
    Lanarkshire
    most bearing noise won't be audible untill more than 10mph in my experince. Try driving on the motorway and if when you change lanes the noise changes as more or less pressure is put on each wheel it is likly to be a bearing
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Maybe someone on here that lives near you wouldnt mind swapping your wheels with theirs for a few minutes. See if its wheel/tyre related or something else.
    Maybe just swap 2 at a time, see if its front or rear.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Does the sound change as you go over different surfaces?, best place to try is usually county boundaries, since each county is responsible for it's roads, quite often, the tarmac changes on the boundary line.
    If the noise changes, it's a tyre issue, if it remains constant, then a bearing.
    Nov 2007
    greater manchester
    Quote Originally Posted by Chocki View Post
    cheers for replys, the noise seems to remain constant but i will try that tomorrow to be sure, i will also try changing the front and rear wheels over to see if that makes any differnce.
    if no difference i will try dealers again in the new year as it must be more than tyre related.
    Wilts
    How about swapping each wheel with the spare, and testing it each time?
    Maybe just one rogue tyre
    Nov 2007
    greater manchester
    yeh never thought of that, worth a try, neighbours are going to think im mad but who cares if it cures/indentifies the problem.
  1. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  2. Noisy Top End
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 09:45
  3. Noisy Air con
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 19:19
  4. Noisy A/C
    By multi in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 20:03
  5. noisy air con
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 14:14
