Results 1 to 3 of 3
Thread: af23 gearbox problem
    Nov 2007
    Sydney
    Default af23 gearbox problem
    hi guys i have a problem with the gearbox in my vectra c when my car stops completely it would give a little jerk as if to engage neutral.
    the gearbox has just been replaced along with radiator, and oxygen sensors under warranty 3 weeks ago if that makes a difference.
    Get it back if its still covered. Hopefully someone will be along with a better answer
    Mar 2007
    Australia
    It's normal for a vectra to take time to go into idle.... so I assume the little jerk you get is about 2~3seconds after you fully stopped. Probably not the gearbox problem at all but more like the trottle body and fuel injectors needs cleaning... I read some forums about the idle control valve..but apparently the veccys in australia don't come with one as it's electronically controlled.
  1. Vectra AF23 Gearbox problems
    By PJL in forum Engine & Drivetrain
    Last Post: 19th July 2010, 07:22
  2. af23 auto gearbox problems
    By andyadams in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2010, 21:24
  3. gearbox problem
    By vectra sri dan in forum Engine & Drivetrain
    Last Post: 18th May 2010, 17:56
  4. How do i Know if i have AF23 0R AF33?
    By mikaj in forum Engine & Drivetrain
    Last Post: 2nd August 2009, 14:11
