Results 1 to 10 of 13
Thread: Cruise Control not working
    Sydney
    Default Cruise Control not working
    Hi all,
    Merry Christmas from downunder..
    I am having issues with my cruise control on a 2003 Vectra, 3.2 cdx (Auto).
    It first raised its ugly head when after setting the cruise control it would suddenly switch off for no reason. After a few repeats of this event, it has stopped working and does not turn on at all - i.e. no lights in dash and no control of the speed.
    Dealership has advised there are a number of fault codes (P1565, B3794, B3115, B3601) which would take a number of hours (more importantly $$) to diagnose.
    I have read a number of posts about similar issues, but these symptoms seem different..
    Anyone have any advice on what needs fixing?
    Cheers in advance..
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Mine went a while ago (equivalent UK model, 2003 3.2 Elite Auto).
    What I experienced was CC would switch itself off, and would not work again at all until I'd switched the engine off and back on. This got more frequent over time.
    The dealer diagnosed this as a fault in the CC switch, and the stalk/switch got replaced under warranty, which cured the problem.
    HTH
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    My CC spat the dummy last week, turned on but then within 1-2 seconds turned off again. Did it 4 times then hasnt done it since??
    Melbourne, Australia
    Quote Originally Posted by jonnyc View Post
    B3115 = "Remote Key 2 Not Synchronised"
    B3601 = "Key Capture Relay Circuit Malfunction"
    B3794 = "Cruise Control Switch malfunction"
    P1565 = "Cruise Control Interface Malfunction"
    These codes are probably all related to the CIM (Column Integrated Module), so that's probably the place to start looking... I'd probably replace the stalk (relatively cheap) and if that doesn't fix the problem, replace the CIM($$$).
    I had both these items replaced on my 2003 Vectra under warranty...
    Full Member Big Sig's Avatar
    Also try driving along, lift the clutch pedal with your toe and try the CC. Sometimes the clutch switch spring goes.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mine has switched of on a couple of occasions.. I hope it's not the start of things to come.
    Feb 2007
    North Somerset
    - It's an auto, although it's possible your comment could apply to the brake pedal the fault codes suggest the switch.
    Quote Originally Posted by MysteryElite View Post
    My fault for not reading it fully. But as you say, the same applies for the brake pedal switch
    11 Post(s)
    Not so much the brake / clutch pedal switch, but the pedal return spring itself isn't man enough and needs replacing.
    Sydney
    Cool - thanks for all the responses..
    I'll have to play around with the brake pedal to test.
    stevedee... im assuming you work with this stuff? or you're just some sort of code reading machine.. Can you just buy those parts and fit them yourself?
    I'll also have a go at ripping (.. carefully removing ..) out the CC stalk to check that out as well. too bad i don't have a spare one laying around
    to test.
    I'll let you know how I get on - fingers crossed !
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control not working :(
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 16:16
  3. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  4. Cruise control not working
    By tommyk999 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2008, 11:13
  5. Cruise control not working
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2006, 21:07
vauxhall vectra c cruise control not working
p1565 cruise control interface malfunction
2005 vectra 1.9 cdti cruise control not working
2007 vectra petrol cruise control not working
fix P1565 opel
How does a vauxhall vectra cruise control work
Opel DTC B3601-04
vectra zc cdxi cruise control fault
astra vxr cruise control interface malfunction
which model vectre c has cruise control
cruise control on vauxhall astra 09 doesnt work
https:www.vectra-c.comforumshowthread.php36214-Cruise-Control-not-working
cruise control clutch return issues vauxhall vectra
vectra-c.com cruise control
vectra cdti cruise control not working
cruise control not working vectra c
farthållare problem opel vectra
vectra c cruise control problem
b3115 fault code
