Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Suspension 'Clunks'
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Suspension 'Clunks'
    I've started hearing a bit of clunking which seems to be coming from the suspension.. If I take this in under warranty will I get a courtesy car while it's being looked at? I did with my previous car, but knowing how tight VX seem to be.....
    Regular Member Harry's Avatar
    Uxbridge, London
    is it only when going over speed bumps?
    if so, then it's a common problem with a few culprits.
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Got a feeling mine is starting to do the same, whats the problem?
    Feb 2006
    Guttedsville
    Clunks or twangs? Mine twangs a bit over speed bumps, normally it's the spring seat that needs a mod.
    Vauxhall know all about it, basically a plastic sleeve that fits in the cup over the spring.
    Uxbridge, London
    could be the anti-roll bar bushes aswell, but more likely the spring sleeves
    @home
    Engine : 1.9 CDTi
    It started with speed bumps, but had it happen today when turning, which makes me think it's the springs..
    Regular Member Rob_the_Scot's Avatar
    London
    futher to this, noticed mine makes a sort of 'squish' noise when going over bumps, is this just the cold weather...you can tell I know a lot, LOL
    Uxbridge, London
    that's what mine sounds like Rob - and for me it's worn anti-roll bar bushes.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Ive got the same, warranty ran out last month.
    Is there something i can do myself to this sleeve thingy to see if its faulty ?
    Guys at work recon its the suspention bushes as they have had several go on the company cars, but ive had it checked out a VX and 2 other garages and they found no faults.
    You can hear it when you go over bumps in the road, hard turning like at junctions and speed bumps
    Uxbridge, London
    if you search the forum for spring sleeves you should come up with the part numbers that are required.
  1. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  2. Clunks when starting
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 17:08
  3. clunks and pings
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 16:37
  4. Clunks from rear of car
    By Angelchops in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 11:08
  5. Suspension 'clunks' when cold. Anyone got any knowledge.
    By andrewp3883 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2007, 23:30
