Thread: heater resistor pack
    Jun 2007
    leeds
    Default heater resistor pack
    hi all need to replace this
    had a little look do i needs to remove the glove compartment
    to get to this also when the heater is blowing its squeaking
    so need to have a good look at that as well this weekend
    dont want the thing packing in on me brrrrr
    this time of year
    it's easier with the glovebox out...if you can get to the bearings, give them a little spray of wd40 or silicone grease, that should stop the squeal...and look for signs of water in the fancasing..it should be dry..
    Jun 2007
    leeds
    cheers m8
    i wish good old mr haynes would hurry up with is manual
    would make life alot easier
    uk
    take out the glove compartment (screws top and bottom) the reostat is located just behind the center panel towards the bottom. You cannot see it, it's a feely touchy job but it very simple to replace. 15 min total time! If you suffer from flooding i.e. a wet pasanger floor make sure you clean the rubber drip gator located just below the polen filter (lift the bonnet, under the flap on the right hand side of the plastic winderwiper cover)
    Yes it's experience!!!!!!!!!!!
    Kel
    It's nicer with a boot
    Jun 2007
    leeds
    all sorted now guys thanx for the heads up
    just going to pick a new resister pack up
    cant wait been driving arround in the cold all week
  1. Resistor Pack Replacement
    By EstateMan in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2016, 23:40
  2. Blower Resistor pack
    By jammy_c in forum Bodywork & Interior
    Last Post: 16th October 2012, 20:00
  3. Heater Resistor Pack Help
    By manimal in forum Engine & Drivetrain
    Last Post: 10th November 2010, 19:00
  4. Resistor pack
    By V6 JDT in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 12:28
  5. motor resistor pack
    By timbarny in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 17:17
vectra-c heater resistor pack
