Results 1 to 2 of 2
Thread: 3.2 oil change
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default 3.2 oil change
    In the absence of a Haynes manual, could somebody briefly run through what's involved to change the oil and filter?
    Things I need to know - where is the drain plug, what head is on the drain plug, where's the oil filter located (can't see from bonnet side so guess I need to remove undertrays), what type of oil (5-30 synthetic) and oil capacity.
    I've tried searching the forums but to no avail - hope you guys can help.
    Many thanks
    right....heregoes....
    the drain plug is located on the lowest part of the sump..facing rearwards..it's a T45 TORX insert and will be quite tight..The oil filter is not a conventional steel can, but a replaceable element. The housing is found down to the front right of the front exhaust manifold..it's an alloy casting with a nut cast onto the top of it, yet again it will be tight..don't forget to replace the o rings on both the sump bolt and the oil filter housing
    There are no undertrays on the 3.2V6 to remove, so access is superb..
    refill with 5W30 fully synthetic oil using 4.75 litres..
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
