Results 1 to 10 of 13
Thread: Signum Heating System Problem
    Feb 2007
    Gunnislake
    Engine : 1.9 CDTi 120
    Default Signum Heating System Problem
    Car has Climate control which I set always in Auto.
    It started when the left hand face vent started blowing a lot hotter than the right despite settings being the same.
    Now I am having to run in ECO mode as the heating is now practically non existant.
    Questions
    1/ Is temperature control acheived by balancing air flow thru / not thru heater matrix?. If it is it may a flow valve is stuck.
    2/ Are these devices getatable without major work?
    [Ex]Admin Duncan's Avatar
    1) There are servo valves for each vent that mix the warm and cold air, so sounds like one of those had gone.
    2) Yes, just needs removal of the glovebox and footwell centre console trim for passenger side servo, and just the latter for the driver side.
    Feb 2007
    Gunnislake
    Thanks for that info are all servo valves in that area because I am getting no hot air anywhere or do you think the problem may be elsewhere?
    Ah, if no hot air at all then that would point at something else. Is the car warming up? i.e. is the temp gauge rising to it's normal temp? If not, then a thermostat is a likely culprit. If it is rising normally, then you could be looking at something more major in the heating system.
    Feb 2007
    Gunnislake
    I am getting some warm air the car temp gauge is 80-90
    Feb 2007
    Gunnislake
    If I switch to manaul vents I can get hot air out of the face vents so I am now assuming the problem lies with the Auto control !
    sounds like the temperature probes in the Climate control to me...there's one for each split side...
    Feb 2007
    Gunnislake
    Well car went in they replaced the control unit and one servo
    £430 the poorer got it back and yes slightly warmer but rubbish
    Went back today oh yes sir tester cam back sweltering 53C from vents
    Rubbish no difference cold air from vents with a tinge of warmth
    Questions to those with Climate
    When turning temp to max what fan speed do you get? (AC on Auto) mine shows 5
    Regular Member EURO G's Avatar
    n ireland
    mine shows 5 as well
    Feb 2007
    Gunnislake
    Quote Originally Posted by stepheng View Post
    So when you turn to max is the air flow strong on the outer vents when open and how hot is is it? Do you also get hot air to screen and centre vents ?
    P.S. Thanks for your reply
  1. Central Heating System Cleansing using Fernox Stuff - Help Please
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 4th February 2013, 10:32
  2. Help bleeding the heating system on vectra c 1.8 ls
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2010, 00:34
  3. Pre Heating System??
    By blanch in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 13:29
  4. 2.0 dti heating problem
    By jmacp in forum Bodywork & Interior
    Last Post: 23rd November 2008, 13:42
  5. sludge in central heating system
    By moorlander in forum The 'Off Topic' room
    Last Post: 27th September 2008, 08:06
