Thread: light ticking noise
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Default light ticking noise
    i have noticed when i come to a stop turn the car of there is a light ticking noise coming from behind the dash and only lasts for a few seconds.just wondering if anyone else has noticed it or knows what it could be?its not affecting the car in any way just wondering
    [Ex]Admin Duncan's Avatar
    Oct 2007
    Back in Belfast!!!!
    cheers duncan that could be it i have pm'd sig 63 to see if thats what it was and if he got it sorted.my car still has warranty so altho there do not to appear to be anything wrong with the car would like to get it sorted. sorry hijacking my own thread, you get your towbar on yet duncan i am definetly going to get mine on before xmas!!
    No probs m8.
    Re towbar - picked it up yesterday from Matt (Maverick) but it's gone straight in the garage, Just got too much to do. As I don't need to use it straight away, I'll fit it after Christmas.
    Nr Cardiff
    The servo motor on my Climate Control has failed completely. Does anyone know whether this is an easy DIY fix or is it a dealer job?
    Jeez m8, you really aren't having much luck with that car are you?!!
    As for the job, it looks fairly straightforward. I'm assuming it's the passenger side mixed air valve servo you're meaning? It's a case of glovebox out, footwell panelling on the centre console off and then you'll have access. Same if it's the driver's side, less the glovebox removal. Straight replacement and no Tech 2 seems to be needed for anything.
    HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My air re-circ servo is still broken from a couple of months ago. I removed it and secured the flap on the air directions ducting to be sucking in from outside always (used a shoe lace, as that's all I had !)
    I'll fix it someday, but there's no rush
  1. ticking noise when air con on.
    By philc1210 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 20:42
  2. ticking noise
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 21:07
  3. Ticking noise
    By trickyjacks.4 in forum Engine & Drivetrain
    Last Post: 23rd February 2011, 15:33
  4. Odd ticking noise
    By Big Sig in forum Engine & Drivetrain
    Last Post: 20th June 2009, 22:54
  5. Ticking noise
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2007, 19:08
