Results 1 to 9 of 9
Thread: Gear Changes
    Larkhall
    Default Gear Changes
    I had a go in manual mode tonight but i forgot when to change gear!!
    I had lessons in a manual before switching to an auto instructor. What gear would you use for certain speeds and when would you change down to a lower gear???
    I'm going to use it all day tomorrow just for a wee change but the car ends up revving as i change down too early.........
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    7 Post(s)
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    common sense tam lol
    You can just tell from how the cars sounds, whether it's labouring etc. or whether you're revving the tits off it. No hard and fast rules, it's just feel and common sense really.
    Edit: lol, you beat me to it pogo! lol
    Regular Member Flaninacupboard's Avatar
    Oct 2006
    Wellingborough
    i tend to do:
    1 pulling away and then
    2 up to 20 and then
    3 up to around 35 and then
    4 up to around 45 then
    5 up to about 55-60
    6 up to as high as i like.
    That's for normal/relaxed drving. if i were for instance going off a roundabout and up a slip road:
    1 up to about 15
    2 up to about 45
    3 up to 70
    6
    or on a motorway probably add in a bit of 4 to get to crusing speed before resting into 6.
    Larkhall
    Quote Originally Posted by vectrapogo View Post
    I'd hate to see me driving a manual!! I'd also hate anyone seeing me driving one.........
    After spending 2 years in an auto it feels weird even being a passenger in a manual.
    Technical directors office
    it all depends on the engine's speeds..if you down change too early,as you've found it over revs....
    try to avoid big RPM downchanges, the box really hates them....
    Regular Member AndrewTi's Avatar
    Feb 2006
    Guttedsville
    On the 2.2 Dti. I found the usefull rev range to be between 1750 and 4000 rpm. Just practice keeping it between those.
    Also, reckon on an upchange or downchange being worth between 1000 and 1500 rpm, depending on gear and roadspeed.
    Keep playing, you'll get to know it by ear.
    Regular Member Karl's Avatar
    Sunderland
    leave it in auto and enjoy the ease of driving! lol
    For economy I change at 2-2.5K, around 4.5k when having fun
    Downshifts are harder if you have never learnt in a manual, especially as an auto box has different ratios to a manual.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    fun is in the red line!!
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
