Results 1 to 10 of 19
Thread: Can anyone help?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Default Can anyone help?
    Ok sorry this question is not vec/sig related but the thing is that my sis got home today with her new car a bwm 316 compact r reg and the problem is that the heaters arent blowing hot air even when the engine is hot.She says that it blows hot air when above 40 and if she turns the heater down to cold the air does blow cold?I heard before that it could be related to a head gasket prob so i checked the water levels they are fine and there is no white residue on the oil cap.Any help would be greatly appreciated,thanks.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Is the car actually getting warm? (ie does the temp guage move?)
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    Default heat
    Quote Originally Posted by Stuarty View Post
    could be a resistor happened to me before on my rover 400 years ago
    Aberdeenshire
    Yeah the car is warming up fine and the temp gauge is in the normal heat range?Never heard of a resistor in the heating going before i also checked the floor to make sure it wasnt wet just in case it was the matrix.
    Feb 2006
    Guttedsville
    Nah, that'd be the fan not blowing at certain speeds. Thermostat or a blocked pipe to the matrix?
    Aberdeenshire
    U reckon changing the stat may help il try take it out and put it in boiling water and see if its opening.
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Is that 40 degress or 40 mph? its not air locked and needs bleeding off is it?.
    Feb 2006
    Guttedsville
    Changing the stat can't hurt.
    Also, do a full coolant change at the same time.
    Aberdeenshire
    Quote Originally Posted by WHOOSH05 View Post
    40 mph mate il hve a good look at it tomoz dit get cance today.
    Aberdeenshire
    Quote Originally Posted by AndrewTi View Post
    Yeah pob a good idea i said id do the plugs and oil ect so il do the coolant aswell.
