Thread: Which fuse?
    Regular Member Adam's Avatar
    Dunstable, Bedfordshire
    Default Which fuse?
    Hi all,
    Which fuse controls the electronics fault/engine management lights? The manual isn't showing anything obvious, and I don't want to pull out random fuses.
    if you want to remove the fault light, just disconnect the battery for 15mins.... or get the codes reset..
    Tried that but the fécker keeps coming back on. Gonna try and change the fuse, just in case. Which one would it be?
    if it keeps coming back on, then there's a 'live' fault with the car, and there is no fuse that you can remove to sort that out..
    it needs investigating properly....so it's code reader time..
    That's all been done. Trust me on this one - I need to remove the fuse :P
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by Vectra-C's resident Technical Man
    Quote Originally Posted by Adam View Post
    Your a Brave Man questioning Mark's verdict on a Vectra related mechanical issue!!
  1. Fuse box
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:01
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. help fuse box
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2011, 19:24
  4. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  5. fuse box ID
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2009, 13:17
