Thread: n/s foglamp
    Regular Member dave b's Avatar
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    Default n/s foglamp
    Can anyone see a potential problem in wiring in the n/s rear foglight with a bridge wire from the o/s one? I dont want to confuse or damage the ecu. Also, does anyone know how the interior lights are operated by the doors? I cant find any swiches on the doors or doorposts.
    the switch for the doors is intergral with the door locks..
    bridging should be okay, but the feed wires aren't all that big...why do you need to bridge BTW...?....the front fog loom is easily avaliable and is quite cheap...
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    mite he be talking about the bk ones mark ??? only guessing as he said rear
    Mileage : 000
    I thought he was talking about the rear as there is only one, and I got the impretion he wanted to wire the two so the both would work from the "live" side.
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    Default n/s rear foglight
    Yes,I was referring to the rear foglights,the idea being to have two rear fogs, just like all my previous Vauxhalls.Pennypinchers !
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    yep theres no prob in doing that m8
    Mileage : 000
    Mind you I do agree with the pennypinching idea, but the idea of one rear fog is supposed to be so the bloke behind can see the brakelights come on and not getcofused, me I prefere two rear fogs so "he" does not run into the back of me.
    13 Post(s)
    Quote Originally Posted by soulman View Post
    I thought there's been previous mention of it upsetting the canbus?
    Also, if you've got optional blown bulb checking, won't it also screw up this as the current being drawn through the fog light wire will be double what it's supposed to be?
    SUFFOLK
    If you got bulb check this will no work as the bulb check see it as a short and then neither bulb will work.
    I did do this on previous vec C but instead used a relay to drive the second bulb which sorts the bulb check problem.
  1. Demisted front foglamp
    By john_k_sri in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2009, 11:05
  2. FogLamp - Warranty?
    By Small Racer in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 22:18
  3. front foglamp harness
    By andy.l in forum Parts for sale
    Last Post: 3rd May 2009, 20:18
  4. FOR SALE: foglamp surround
    By John3v36 in forum Parts for sale
    Last Post: 27th March 2009, 15:41
