Results 1 to 10 of 26
Thread: Snow flakes on forum slowing me down
    Regular Member muffking's Avatar
    Default Snow flakes on forum slowing me down
    This isn't a rant type post, but I wondered if it's just my PC slowing down to an almost dead stop on the forum since the snowflakes appeared. Normally PC is quite fast, but if the snowflakes keep slowing my PC down then I'm just going to have to give the forum a rest until after xmas as I can't browse through the forum.
    not slowing it down here....
    Veiwing the forum on a COMPAQ lappy, running AMD Turion64 with 2GB..and over our Wi-fi as well..
    Regular Member cabbage's Avatar
    Bristol
    Yeah, Bah, Humbug, the bits of pixels that keep flying around must be dandruff from the moderators. Use Head and Shoulders.
    Whats genner happen when the snow starts piling up at the bottom of the screen? Can we download a virtual snowplough?
    Quote Originally Posted by cabbage View Post
    What on!!.. i've got no flamin hair....
    it's fine.. it just settles on your monitor stand, so just wipe it away..:..
    I'm using a 2Ghz Sony Vaio over WiFi which normally runs a ton of Ebay windows, but since the dandruff appeared as cabbage says my mouse jerks around and trying to scoll down posts even using the cursor arrows takes a while so I have to close the window to get back to normal speed again.
    May 2006
    n.ireland
    its only single moving pixels mate, Its not like its using heavy shadows or taxing the shader unites. What gpu do you have, Is it on board? Also gsi3.2, your cpu and ram would not be a factor, It will be the gpu in your system which I am sure will be a ati chip as they are now owned by AMD.
    So in summery
    very low gpu recourse usage, It wont even make your gpu run in 3d mode.
    but you do experience problems so there must be something going down. I would recommend updating your gfx drivers.
    Yep, ATI graphics card on this and the Wifes AMD lappy as well....
    It listed as an NVIDIA GeForce Go 6200 if that helps.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    It's javascript (snow.js) so all the calculations are done on your CPU, not the GPU. What browser are you using and are you seeing 100% CPU usage when on the forums?
    Regular Member simac's Avatar
    Wirral
    I have a strange problem too. Since the snow flakes my PC won't display the "bubble" when I hover the cursor of the titles of posts.
    My PC in work does it fine though !
  1. Snow Flakes
    By Mart2823 in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2011, 14:00
  2. 19" snow flakes
    By drbeansri in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2010, 12:31
  3. Snow flakes?
    By WilliamLX in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 12:06
  4. flakes in the snow!
    By moorlander in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 19:46
