Results 1 to 10 of 13
Thread: Topping up oil
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Default Topping up oil
    Hi all
    Checked my oil today and noticed its a bit low, so i bought some 10w/40 fully synthetic to top it up.
    If it might have Vauxhalls own 5W/30 in it will it be a problem?
    It has not had a first service yet, so should have the factory oil, but bit worried about mixing them and F-ing it up
    Nr Cardiff
    Can't see how it would hurt at all to mix them, personally I wouldn't worry about it and put it in. I'm running fully synthetic coach oil in my car at the moment.
    Got it free from my mate who runs the garage there. 0w/40, they change the oil every 100 000 miles with this stuff so 20k in my car won't hurt it much!!
    Jonesy..how much did you add??..
    Co Antrim
    none yet mate
    alright them....how much down the dipstick is it?..
    Co Antrim
    Close to the low level
    so it wants about a litre....that level of dilution (25% ) means that i'd shorten the next service interval...rather than 20,000 i'd drop it to 12,000..just to be sure.
    I know some will knock me for it, but if it's a brand new car , it's all still tight and the oil takes a real beating...I'm well known for being no fan of extended drain intervals as our cars are always paid for by us, so why ruin the 2nd biggest investment you ever make for the sake of an oilchange?..
    Co Antrim
    got 17k on it, booking it in for the 20k service
    well, in that case , it isn't going to hurt it a bit...in it goes.....
    Top Tip...ask them what oil grade they refilled it with when you get it serviced...a popular 'dodge' is to refill it with 10W40 semi synthetic, reset the service indicator to 20,000 and let you have it back...the problem??..10W40 semi synth is only good for 10-12,000 miles.....it's not longlife...But it's dead cheap for the dealer to buy, so increasing their margins on the service...
    If they use 10W40, make them drain it and change the filter again....
    Co Antrim
    Update, checked oil again, and it was halfway between min and max.
    Was at a mates lockup tonight and he is in the vaux trade club, going to get 20 litres of fully synth 5w30 and 4 oil filters for about 70 quid and do interim services in between the 20k ones
  1. Topping up brake fluid
    By R2XPT in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2011, 11:12
  2. Topping gearbox oil up on 2.2 DTI
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 15:35
  3. oil smells and seems to be topping its self up
    By sharpy22 in forum Engine & Drivetrain
    Last Post: 8th June 2010, 17:37
  4. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
  5. Topping up gear box oil
    By jamesr in forum Engine & Drivetrain
    Last Post: 30th March 2008, 14:09
