Results 1 to 10 of 15
Thread: Suspension help required ASAP
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Default Suspension help required ASAP
    ok
    im outside with me mate in the freezing cold.
    we have removed the strut but are having problems removing the top mount bolt, we have the tool for the insert and the socket but can only use one at a time (due to the black surround)
    What can we do?
    HELP ASAP
    Belfast
    With the Astra, I had similar issues. Jacking the car up and getting someone to stand on the brake disc/caliper gave enough downwards force on the top mount to stop it spinning. A sharp tug on the ratchet freed it no bother.
    Aug 2007
    Great Wyrley
    well ive sent me mate down halfords to get a 21mm with an angle on it, ive got everything bar a 21mm with the angle to get in at the bolt.
    Grrrr never an easy job when i do something
    He rings, Halfords dont do a 21mm with an angle FFS im gonna end up putting this back together at this rate
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Gregg, We usually use an Air Gun to get them off..
    Take them off, and go to a Tyre and exhaust centre and ask if they can whizz them off for you..
    Aug 2007
    Great Wyrley
    well we have got the 21mm nut moving but its access to the little start shaped screw we are having problems with as we cant do both at the same time.
    combined with that its frezzing out here, i would take to a local garage but there all tits around here, never ever want to help you out unless your taking work there way and you paying for it
    hopefully 21mm spanner on an angle is available at B and Q then we can carry on as we were, if not its gonna have to be put back together and left for some other time
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    When I did mine I used a 21mm socket on the nut but used a pair of mole grips on the socket so I could
    fit a long torx bit through the centre of the socket. It worked a treat for me.
    Jun 2007
    Any luck yet Gregg??
    Gregg... you need to get a set of 'vortex' sockets from halfords that go that big.. then you can still get an insert bit into the end of the damper shaft..
    Aug 2007
    Great Wyrley
    Well we got them done
    in the end used a screwdriver to hold the nut on place and then used the torx.
    Uothadox but there done, cars looking really good and handling really well, put it this way 2min drive to the shops took me 40minutes HAHA
    Ill get before durig ad after pics up tmrw as its too dark for the after pics now
    Tamworth
    Quote Originally Posted by Gregg View Post
    My hands a still blooming freezing but came out ok in the end didnt it!! my magical touch with the screwdriver loL!!
  1. cdti whistle help required ASAP
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2010, 14:08
  2. vec c mirror required asap!!!!
    By kojak01 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 22:16
  3. Oi filter help required ASAP!
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 3rd April 2007, 15:44
  4. Help required asap with wing mirrors
    By Matt21385 in forum Styling
    Last Post: 29th May 2006, 23:09
  5. Help required ASAP!
    By Matt21385 in forum Handling & Braking
    Last Post: 19th May 2006, 19:40
