Results 1 to 4 of 4
Thread: Engine problem tonight, cut out.
Hybrid View
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Unhappy Engine problem tonight, cut out.
    Well it's going again but heres what happened. I was leaving work, not too cold out tonight as it has been. It started to have a couple of what I can describe as jolts, maybe mis-fires?, then it just cut out, lost all power. I coasted into a luckily placed parking spot and switched the ignition off. When I tried to re-start it as vibrating like mad but the engine wouldn't start.
    So first thing I do is pull out the caterman box. It's the only thing I have, and if it's towed then I dont want that in there for vaux warranty to see.
    So I do that, get it and try to start again, starts, no problem. Decide to chance it and drive home 35 miles with no incident at all, feels smooth and good as always.
    So I dont know what the problem is, there is a fault stored in the computer so I'll take it in on Monday to get them to see what it was.
    Could it be down to the tuning box gone bad? I might put it back in tomorrow to see.
    Any other ideas?
    Technical directors office
    if it's the box.. it could be any number of fuelling related problems..it'll be good to see what they come back with..
    Oct 2006
    Saffron Walden
    I guess theres no way to find out what the stored code is without a tech reading it?
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Engine : Z19DTH
    Year : Nosey
    Excess common rail pressure is where my money is! I've tried pumping the rail pressure up on the remap to some pretty high levels and it starts to throw a fit at between 1900 and 2000 bar. Just says no and stops, strange as I know the pump can do more when I slap on the box over the remap. Anyway, it is not unusual for the box to need adjusting for different weather conditions, if your's does not have adjustment then you might not be able to use it again until it warms up again.
  1. engine problem
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 19:30
  2. Tonight on BBC's Watchdog - Vauxhall fuel pressure regulator problem
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 18:53
  3. problem with engine
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 18:36
  4. 2.2 Engine problem
    By hamish178 in forum Engine & Drivetrain
    Last Post: 8th November 2007, 00:40
  5. Derrin Brown tonight Channel 4 10.00 pm tonight
    By Stevel in forum General Chat
    Last Post: 29th December 2006, 23:00
