Thread: Noisy pulley/water pump
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Noisy pulley/water pump
    On my 55 plate sri cdti 30,000 miles on the clock. The noise is coming from the side of the engine with the belts on. It's more audible when the car is started form cold. Has anyone had any problems like this? Am i panicing over nothing or should i pop into dealership with it and let them be the judge?
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    I would say dealers mate as its under warranty
    Ashington, Northumberland
    Use the warranty mate. May be alternator pulley or such other expensive item. Then again, could simply need a new belt on.
    [Ex]Admin Duncan's Avatar
    I had a similar problem and ultimately it needed a new tensioner and alternator pulley. The pulley isn't cheap so if you can get it under warranty, definitely.
    S.Lanarkshire
    Problem solved. It was a dry belt it was solved by using a magic spray (wd40). It's caused by all the crap of the road drying the belt out aparently.
    Quote Originally Posted by rosssri View Post
    It'll just start again mate, better off fitting a new belt tbh
    S.Lanarkshire
    Quote Originally Posted by GARY3306 View Post
    I know and trust the mechanic who dealt with the problem and he told me not to worry about it. His words good enough for me
  1. EHPS Pump very noisy
    By alanlush in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2012, 14:47
  2. Water pump.
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 24th September 2012, 22:19
  3. fuel pump in tank noisy
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th April 2012, 15:00
  4. Fuel pump pulley nut torque
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 18:10
  5. Water Pump
    By Howard Allen in forum Engine & Drivetrain
    Last Post: 3rd May 2008, 22:04
