Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Traction Control & ESP
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Default Traction Control & ESP
    Dense question..... but do you only get TC with ESP ? All my Veccys have had it as standard so far but it seems the new C's dont have bog standard TC and I have to ask for ESP... ( he he ESP - you need it now a days with some drivers ) ... to be fitted as an option..... ?
    Terran
    as far as i'm aware, they all have TC.. just not the switch to turn it off...
    Cirencester
    my 06 design 1.8VVTi doesnt have TC. wish it did tho
    Oct 2006
    Wellingborough
    Nope, only standard on V6 models now. ESP/TC is a £400 option on all other engines.
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    TC comes with ESP now.
    You used to get TC as standard on most models until the change to facelift.
    MMmm - not sure I follow the logic of Vauxhall bar £ related terms. I've found TC to be handy in many a case when in wet weather and pulling out of a junction etc etc.... ESP I can follow too.... I just cant see why they took it out of the standard line up.
    Terran
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I assume my pre f/l CDTi 150 SRi has TC but it's about as much use as a chocolate fireguard. Does it monitor all four wheels or just the any speed difference between the front wheels?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Ian S100 View Post
    Think it measures the rear wheels and then if the front wheels are spinning at the same speed, if they are spinning faster it applies the brakes - terribly though!!!
    It is useless in preventing understeer though - sorry to say it but Clarkson was right - chassis is terrible but I wouldn't swap the car though for anything else though!!!
    Gazza4
    Regular Member derby4life's Avatar
    North,Shropshire
    I didn't think mine had tc caus it never stops the wheels spinning in the wet
    strange
    cdti sri 150 BTW pre face lift
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The TC doesn't brake, it just cuts power to the fronts if it detects a miss-match between front and rear wheels. If you have TC the little triangle with a skidding car will come up on the dash when the wheels spin.
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
