Thread: wheel well size
    Regular Member shan's Avatar
    Default wheel well size
    Will a 19" snowflake fit into a signum wheel well as a spare.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    As long as you taek put the Polystyrene thing at the bottom i believe it will...
    I know a 215/50/17 will fit in the Wheel Well of a Vectra.
    I think the signum is diferent though, and it wont iirc
    No, not a chance basically. The Signum (and estate) wheel well is shallower than the hatch or saloon - it won't even take a normal 17" wheel as a spare!!
    Jun 2007
    Quote Originally Posted by Bainie View Post
    You can achieve anything with an angle grinder and an Oxy Torch though!!
    Sorry Shan, looks like i was mistaken
    O well. So what would you suggest as a spare if your useing 19"wheels. Don't like the idea of useing the skinny thing that i have at the moment.
    You either have to live with the spacesaver, or put a normal wheel in but put up with the boot base sitting higher up on top. Neither ideal really!
    Jun 2007
    Shan
    You coold always get a piece of MDF measured up and raise the boot floor slightly to make sure there was no Wheel shape in the carpet, Obviously cut the hole for the spare wheel, you could even make it so the wheel is covered by the cut out bit of MDF, and put a small flatish handle on it so you can lift the lid off to expose your spare wheel..
    but you'd have to scrap the lashdown points in the floor....as the bolt down through the carpet..and the 3 other fixings up the 'front' of the boot....
    Can't deepen the wheelwell either, as it's dead tight to the exhausts..
  1. wheel nut size
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 08:26
  2. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  3. wheel size???
    By hagga in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 07:48
  4. sri wheel size
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 18:33
  5. Wheel size 2.2 DTI
    By Haris in forum Styling
    Last Post: 12th July 2009, 18:25
