Results 1 to 10 of 20
Thread: Outside temp sensor
    Nov 2005
    Market Drayton
    Question Outside temp sensor
    Hi
    I am new on here and hope that someone will be able to help me. I have had my 52 reg sri 2.2dti for about 6 weeks and have just noticed that when I switch on the front fog lights the outside temperature display on the dash drops about 8 or 9 degrees. Is this a common fault, or just one on mine? I have tried loading the electrical system with other loads, heated window and fan etc, but the only thing that affects it is the front fogs. It is due to go back to the dealer soon for a new windscreen so I am hoping to have some idea of what it is so I can tell them to fix it.
    I have also noticed the lights (inside and out) flicker particularly when I turn the steering. this is not dependant on speed, although may be slightly worse at lower speeds. Is this likely to be the alternator? Could it also be linked to the fog light/temp problem?
    Thanks in advance for any help
    Regular Member signumT's Avatar
    grimsby
    Quote Originally Posted by Robin
    Hi
    common fault that vxl dont recognise power steering using too much juice so alt struggles (at least thats what i think i was told) please correct me if im wrong
    Melbourne, Australia
    The flickering lights problem is not unusual. The electro-hydraulic power steering uses massive amounts of current. From memory the power steering goes through an 80 or 100 Amp fuse...
    The temperature problem, though, sounds bizarre.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    My outside temp sensor has one up on your's, mine says that it is 41 deg C outside!!! And every day it says the temp is rising, looks like we're in for a heat wave (or a trip the the garage again).
    So was mine yesterday, but it was actually 41 degrees
    Dec 2005
    Sydney AUSTRALIA
    Quote Originally Posted by stevedee3
    yeah - mine is saying 45c, because it actually is !
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Not sure if the Vec C is the same as some other cars I have seen, I have retro fitted front fogs to my old man's Rover 75 (which runs a CanBUS type system), and the wiring lom for the temperature sensor is in the same one as the external temperature sensor.
    Regular Member Ozz's Avatar
    Sydney, Australia
    Well mine was saying 44" stinking hot degrees, because it actually was 44" stinking hot degrees.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by kojarena
    Quote Originally Posted by Ozz
    You know, you can go off some people very quickly!!
    Here's us freezing our ar*es off and you lot are in a heatwave! TBH, I think I'd rather be a bit cold than have the sort of temperatures you guys are having, must be a bit unbearable at times!
    Must be weird (well to us anyway) to have blazing heat at Christmas/New Year! Hope you had a good one anyway!
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Yeah, the problem with mine is that is says 48 deg C while the car is covered in ice...
    I prefer cold to hot anyday, I can put more jumpers and bigger coats on but I can't remove my skin if I'm too warm.
  1. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  2. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  3. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
cannot remove Vauxhall outside temp sensor
vectra c outside temp sensor
vectra c outside temperature sensor reading 45c
