Results 1 to 10 of 11
Thread: 120bhp 8v CDTI tappet noise on new engine
    England
    Default 120bhp 8v CDTI tappet noise on new engine
    Hi all,
    Is it normal to get a pretty heavy tappet noise when accelerating on a 2007 1.9 CDTI 120bhp 8v engine?
    Regards and thanks
    StratApproach
    not normal at all....sure it's tappets and not diesel knock??
    England
    Thanks for getting back to me quickly.
    Just been reading up on Diesel Knock - Brilliant - I think your right.
    I've spent the last few days looking up on the internet key words like clatter and not once did it mention Diesel Knock.
    I'll get the car to a garage next week.
    Thanks again.
    StratApproach
    Regular Member Stuarty's Avatar
    Aberdeenshire
    What is diesel knock
    Diesel fuel is intended to ignite instantly upon injection; the measure of this property is the cetane rating. Gasoline is intended to resist ignition until the spark plug fires; the measure of this property is octane. In either type of engine, uncontrolled ignition with multiple flame fronts causes engine damage/knocking. In the case of diesel, if the fuel doesn't ignite upon injection, a pocket of fuel is formed that later ignites due to the pressure rise caused by the main burn. The results are the same as gasoline igniting from the pressue rise before the main burn spreads to it. The multiple flame fronts collide violently, you hear a knocking sound and the engine is subjected to enormous forces that cause piston, ring, valve and connecting rod damage. The weakest component breaks first.
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    oooh look at son getting all technical
    Nice descripton there son, now i know wot it is as well
    Aberdeenshire
    Cheers for the info bud sounds pretty serious is it a timing issue or more of a prob caused by fuel delivery,injectors,feulpump etc?
    timing really, but also poor injector spray pattern...caused by either incorrect installation height or damaged valving..
    Quote Originally Posted by plasma View Post
    Anorak fully on Dad..
    Leicester
    I think quite a few 1.9 8v's are like it, my dads 1.9 CDTi 120 8v sounds quite tappity when accelerating, it's 18 months old now and has been checked out.
  1. strange noise from engine cdti 150
    By kamar in forum Engine & Drivetrain
    Last Post: 12th April 2010, 17:16
  2. New Vectra 120bhp CDTi engine!!!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2007, 18:30
  3. Is This Engine 120bhp or 150bhp cdti Model? (picture) enclosed!
    By Longtallhowie in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 23:18
vectra c 120 8v engine knocking
