Results 1 to 10 of 15
Thread: Dashboard marks
    Larkhall
    Default Dashboard marks
    The car has a couple of marks on the dash probably from a Sat Nav being stuck on it. Some of the sticky stuff is stll there. Is there a way of removing the stuff as well as the marks?
    I've tried all the sticky stuff removers but they just made it look worse..........
    Feb 2007
    Glasgow
    Turpentine or white spirit usually works quite well as a solvent for removing the residue left by sticky pads.
    Mileage : 000
    What about meths.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Quote Originally Posted by ed taylor View Post
    What about meths.
    Shlurp......... delicious/
    Our you could steal some nail varnish remover from a female relative. Or Acetone, which is what it's based on.
    Phil
    Regular Member fields's Avatar
    Mar 2007
    Lincoln
    I would be careful using Acetone. It will melt some plastics.
    I know found out ot my own cost.
    [Ex]Admin Duncan's Avatar
    You definitely don't want to put acetone (or nail polish remover - same thing) on the dash, it'll strip the plastic/rubber finish. Try some Isopropyl Alcohol (Isopropanol) as that will shift stick stuff without wrecking the plastic. Or try a bit of AutoGlym intensive tar remover if you have some of that.
    Larkhall
    Would turpentine or nail varnish remover do any damage??
    Edit: Whoops to late!!
    I'll give the tar remover a go!!
    Feb 2007
    Glasgow
    The AG Tar Remover is pretty much white spirit It just costs more
    Larkhall
    White spirit do any damage?
    Mar 2007
    Lincoln
    (Try some Isopropyl Alcohol (Isopropanol) as that will shift stick stuff without wrecking the plastic. Or try a bit of AutoGlym intensive tar remover if you have some of that.)
    Just make sure its not Isopropanenitrate (AVPIN) thats a kind of.. err ...rocket fuel.
  1. What are these marks ?!
    By moorlander in forum Detailing and Car Care Discussion
    Last Post: 23rd April 2012, 19:14
  2. Top marks for LMF
    By gtr1000 in forum General Chat
    Last Post: 6th October 2011, 15:08
  3. swirl marks
    By sambo in forum Detailing and Car Care Discussion
    Last Post: 21st July 2007, 16:44
  4. Swirl marks
    By T4M in forum Detailing and Car Care Discussion
    Last Post: 11th July 2007, 16:57
  5. polish marks
    By scott_150cdtisri in forum Detailing and Car Care Discussion
    Last Post: 27th March 2007, 17:33
