Thread: Very Poor Radio Reception???
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Default Very Poor Radio Reception???
    Over the last few days I have noticed that my radio reception (CDR2005) has been very poor, even stations like Radio 1 and 2 are very 'hissy' and the radio keeps going into search mode.
    I have not touched anything on the car and I have always have had good reception in the past. Could this be anything to do with the cold weather, or is it more likely to be a problem with the radio or aerial?
    Any ideas?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Not so much cold weather, as high pressure -mine's been a bit pants recently on FM. have a look here: http://www.bbc.co.uk/reception/analo...eception.shtml
    Phil
    if not, it could just be corrision on the aerial base....stopping it making a good contact..
    Feb 2007
    Northampton
    I have unscrewed the aerial and checked the thread and base but they seem fine
    I am hoping it is high pressure although there are no reported problems in my area
    I will wait and see!
    Northants
    Is it possible to remove the base from the roof to check and cleanup any corrosion? Is it easily accessible if the roof lining is pulled down a tad? Just asking because reception has been poor on my CDR2005 for months, and AM is almost unlistenable, which is not good for a 5 live addict...
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Every Vec C i've had has had a pants am reception....changing the base does little as it is normally the cars systems that cause it....the last one i had done under the Q was being caused by a rear ABS sensor which was interfearing as soon as the wheel began to turn.....
    Northants
    Quote Originally Posted by IamtheStig View Post
    I have exactly this problem with mine, interference that is proportional to road speed, my local dealer can only say "there's a bad earth somewhere" which isn't too helpful...
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yep i have the same probs on AM.........always try and listen to the footy when driving bk from my parents on saturdays........pants reception is an understatement
    Nov 2005
    Somewhere in time
    just found this....http://www.pure.com/Products/Product...PageType=Intro
    Might be a cheaper way to listen to the footy than letting the stealers loose...
    Larkhall
    Mine is the same, although it gets worse when i switch on the rear window de-mister.
    I'm going to get an interference suppressor fitted rather than have the dealer sort it.
  1. Poor fm radio reception (CD70)
    By av2009 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2013, 18:51
  2. poor radio reception with 8k HID's
    By tights in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 00:17
  3. Poor Radio Reception Please Help
    By dizzy in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2008, 17:25
  4. poor radio reception ??
    Last Post: 16th October 2008, 16:34
  5. Poor Radio Reception
    By testbloke in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2008, 23:11
