Thread: fault scanner
    Regular Member dan1983's Avatar
    North London
    Default fault scanner
    hi ive just bought a opel-tech2 obd scanner, but cant get it to work, has anyone else used one of these or a similar one?
    Feb 2007
    Glasgow
    It probably doesn't support CAN bus, the cheaper ones tend not to.
    yep, CAN compatible ones are different to OBDII ones... it has to state it's CAN compliant..
    I've used several, and settled on a PC based dealer level package for home use.
    Jul 2006
    Mexico
    Quote Originally Posted by dan1983 View Post
    Don`t doubt what the other members said, but just to take care of the obvious....after you plug the code reader the ignition should be position I (half on sort of speak)
    HTH
  1. U480 Fault Code Scanner
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 13:48
  2. fault scanner for 2002 diesel
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 22:53
  3. Engine Management Light, fault doesn't show on U480 scanner
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:51
  4. OBD 11 fault scanner.
    By Hoffmeister in forum Engine & Drivetrain
    Last Post: 24th October 2008, 13:30
  5. U581 Fault Code Scanner
    By robzc in forum Engine & Drivetrain
    Last Post: 8th December 2007, 14:48
